Improve productivity and efficiency with an easy-to-use printer that delivers the best bang for your buck.
You can easily print directly from your mobile device to the printer over your wireless network. Unlock your full potential with a mobile solution that allows you to print images, PDFs, and the full suite of Microsoft Office documents, including Word, PowerPoint, and Excel. You can work smarter and faster by harnessing the power of advanced Samsung connectivity.
Now impressive professional-quality prints are possible for everyone. Your Samsung Xpress M2835DW Series delivers sharp, clear prints that are sure to make a big impact. Thanks to its 4800 x 600 dpi effective resolution and Rendering Engine for Clean Page (ReCP) technology, you can enjoy higher performance and quality without the need for a bulky larger printer. What's more, quality-boosting features give you more detail, smoother images and clearer text.
Product Description | Samsung Xpress M2835DW - printer - B/W - laser | Printer Type | Workgroup printer - laser - B/W | Weight | 7.4 kg | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) | Min Media Size (Custom) | 76 mm x 127 mm | Max Media Size (Custom) | 216 mm x 356 mm | Print Speed | Up to 28 ppm - B/W - A4 (210 x 297 mm) , Up to 29 ppm - B/W - ANSI A (Letter) (216 x 279 mm) | Max Resolution (B&W) | 4800 x 600 dpi | Automatic Duplexing | Yes | Interface | USB 2.0, LAN, Wi-Fi(n) | Processor | 600 MHz | RAM Installed (Max) | 128 MB | Language Simulation | PCL 5E, PCL 6, SPL (Samsung Printer Language) | Media Type | Envelopes, transparencies, labels, plain paper, cards, bond paper, recycled paper, cotton paper, thick paper, thin paper, card stock | Total Media Capacity | 250 sheets | Media Handling | 250-sheet paper cassette, 1-sheet multipurpose tray | Monthly Duty Cycle (max) | 12000 pages | Networking | Print server | System Requirements | Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Apple MacOS X 10.5 - 10.9 | Dimensions (WxDxH) | 36.8 cm x 33.45 cm x 20.2 cm |
General | |
Printer Type | Workgroup printer - laser - monochrome |
Printer | |
Connectivity Technology | Wireless |
First Print Out Time B/W | 8.5 sec |
Processor | |
RAM | |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), 76 x 127 mm, Oficio (216 x 343 mm) |
Envelope Sizes | International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm) |
Media Weight | 60 g/m² - 220 g/m² |
Media Feeders | 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² |
Output Trays Capacity | 150 sheets |
Duty Cycle | |
Networking | |
Security Protocols & Features | Wi-Fi Direct |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 |
Miscellaneous | |
Consumables Included | 1 x toner cartridge (black) - up to 1200 pages |
Power | |
Power Device | Power supply - internal |
Power Consumption Operational | 400 Watt |
Power Consumption Stand by | 45 Watt |
Software / System Requirements | |
OS Required | Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Apple MacOS X 10.5 - 10.9 |
Environmental Standards | |
ENERGY STAR | Yes |
Environmental Parameters | |
Sound Emission (Idle) | 26 dBA |
Sound Emission (Operating) | 50 dBA |
Dimensions & Weight | |
Width | 36.8 cm |
Depth | 33.45 cm |
Height | 20.2 cm |
Weight | 7.4 kg |
