HP Color LaserJet Pro MFP 4302fdw
free standard delivery
£509.24
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Support your business workteam with this compact, high-performing, color printer, ideal for up to 10 users.
  • Centralize your print fleet management. HP Web Jetadmin easily adds and updates devices and solutions.
  • Get printer fleet security out of the box. Preconfigured settings mean it's ready when you are.
  • Redesigned Original HP TerraJet Cartridge for reduced plastic use and energy consumption when printing.
  • Type: Fax / copier / printer / scanner, Multifunction
  • Functionality: Copier, Printer, Fax, Scanner
  • Output Type: Colour
  • Wireless Capability: Wired, Wireless
  • Technology: Laser
Product codes
chevron icon
chevron icon
Get a blazing fast colour printer and easy management tools with LaserJet Pro.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
chevron icon
Product Description HP Color LaserJet Pro MFP 4302fdw - multifunction printer - colour
Device Type Multifunction printer
Fax Type Plain paper
Localisation English, German, French, Italian, Spanish / Europe
Printing Technology Laser (colour)
Monthly Duty Cycle (max) 50000 pages
Recommended Monthly Volume 750 - 4000 pages
Max Copying Speed Up to 33 ppm (mono) / up to 33 ppm (colour)
Max Copying Resolution Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed Up to 33 ppm (mono) / up to 33 ppm (colour)
Max Printing Resolution Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Fax Transmission Speed 33.6 Kbps
Fax Resolutions 203 x 196 dpi, 300 x 300 dpi, 200 x 100 dpi
Scanning 600 x 600 dpi
Display 4.3"
Original Size 102 x 152 mm (min) - Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 50 sheets
Media Size 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, glossy paper
Standard Media Capacity 300 sheets
Max Media Capacity 850 sheets
Bypass Feeder Capacity 50 sheets
Output Trays Capacity 150 sheets
Automatic Duplexing Yes (printing)
Connection Availability Yes
Interface USB, USB 2.0, Gigabit LAN, USB 2.0 host, Wi-Fi(ac), Bluetooth LE
AirPrint Enabled Yes
Office Machine Features Scan to e-mail, scan to folder, Private print, HP Auto Wireless Connect, scan to Cloud, Instant-on Technology, Mopria certified, HP Auto-On/Auto-Off Technology, HP Instant Ink, scan to PDF, walk-up USB printing, scan to USB drive, Terrajet Cartridge
Power AC 230 V (50/60Hz)
Dimensions (WxDxH) 42.1 cm x 43.5 cm x 38.4 cm
Weight 20.4 kg
Environmental Standards Blue Angel
Manufacturer Warranty 1-year warranty
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£509.24
