ITEM | QTY | PRICE |
OtterBox Symmetry Clear Apple iPad 8t...
3 | £92.28 |
LG 50" UR7800 4K Ultra HD Smart TV
3 | £897.00 |
Introducing the professional color inkjet printer designed for distributed offices and hybrid workforces, equipped with advanced technology to facilitate efficient management of all printing needs, seamlessly integrating into any network.
Product Description | HP Officejet Pro 9130b All-in-One - multifunction printer - colour | Device Type | Multifunction printer | Fax Type | Plain paper | Localisation | United Kingdom, Ireland | Printing Technology | Ink-jet (colour) | Inkjet Technology | HP Thermal Inkjet - 4-ink | Monthly Duty Cycle (max) | 30000 pages | Recommended Monthly Volume | 2000 pages | Max Copying Speed | Up to 23 ppm (mono) / up to 15 ppm (colour) | Max Copying Resolution | Up to 600 dpi (mono) / up to 600 dpi (colour) | Max Printing Speed | Up to 25 ppm (mono) / up to 19 ppm (colour) | Max Printing Resolution | Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Max Fax Transmission Speed | 33.6 Kbps | Fax Resolutions | 300 x 300 dpi, 200 x 200 dpi, 200 x 100 dpi | Scanning | 1200 x 1200 dpi | Display | 4.3" | Original Size | 127 x 127 mm (min) - Legal (216 x 356 mm) (max) | Original Type | Sheets | Document Feeder Capacity | 35 sheets | Media Size | 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max) | Media Type | Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper | Standard Media Capacity | 250 sheets | Max Media Capacity | 250 sheets | Output Trays Capacity | 100 sheets | Automatic Duplexing | Yes (copying) Yes (printing) Yes (scanning) | Connection Availability | Yes | Interface | USB 2.0, LAN, USB host, Wi-Fi(ac) | AirPrint Enabled | Yes | Office Machine Features | Print from USB flash drive, scan to e-mail, embedded web browser, Mopria certified, scan to SharePoint, HP Auto-On/Auto-Off Technology, HP Instant Ink, IPP printing, scan to network folder | Power | AC 120/230 V (50/60Hz) | Dimensions (WxDxH) | 43.7 cm x 42.18 cm x 31.83 cm | Weight | 11.84 kg | Enclosure Colour | Cement | Manufacturer Warranty | 1-year warranty |
General | |
Printing Technology | Ink-jet - colour |
Display Diagonal Size | 4.3" |
Display Colour Support | Colour |
Display Features | Touch screen |
Memory | |
Standard Memory | 512 MB |
Max Supported Memory | 512 MB |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 99 |
Automatic Duplexing | Yes |
Copying Features | ID Card Copy, collation copy, margin shift, 2-sided copy orientation change, resize |
Printing | |
Inkjet Technology | HP Thermal Inkjet |
Nozzle Configuration | 6272 nozzles |
Ink Cartridge Configuration | 4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black) |
Ink Palette Supported (Colours) | Pigment cyan, pigment magenta, pigment yellow, pigment black |
Colour | 4-ink |
Printer Drivers / Emulations | PCL 6, PDF, PCL 5 |
First Print Out Time B/W | 12 sec |
First Print Out Time Colour | 13 sec |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 x 1200 dpi |
Colour Depth | 24-bit |
Fax Machine | |
Max Transmission Speed | 33.6 Kbps |
Total Memory Capacity | Up to 100 pages |
Fax Machine Features | |
Features | Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending |
Document & Media Handling | |
Min Original Size | 127 x 127 mm |
Max Original Size | Legal (216 x 356 mm) |
Min Media Size | 76.2 x 127 mm |
Max Media Size | A4/Legal |
Min Media Weight | 60 g/m² |
Max Media Weight | 280 g/m² |
Min Media Weight (lb) | 16 lbs |
Max Media Weight (lb) | 110 lbs |
Supported Media Type | Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm |
Supported Envelope Sizes | International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), A4 (210 x 297 mm) |
Document & Media Handling Details | ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 100 sheets |
Speed Details | Printing: up to 25 ppm (A4) - B/W (ISO) , Printing: up to 19 ppm (A4) - colour (ISO) , Printing: up to 39 ppm (A4) - B/W draft , Printing: up to 39 ppm (A4) - colour draft , Copying: up to 33 ppm (A4) - B/W draft , Copying: up to 22 ppm (A4) - colour draft , Scanning: up to 18 ipm (A4) - B/W , Scanning: up to 18 ipm (A4) - colour , Scanning: up to 21 ipm (A4) - B/W duplex , Scanning: up to 15 ipm (A4) - colour duplex , Copying: up to 5 ppm (A4) - B/W , Copying: up to 4 ppm (A4) - colour |
Connections | |
Interfaces | 2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A |
Security Protocols & Features | SSL, TLS, WPA2, 802.1x, WPA2-Enterprise |
Power | |
Voltage Required | AC 120/230 V (50/60Hz) |
Power Consumption Standby | 5.58 Watt |
Power Consumption Sleep | 1.22 Watt |
Miscellaneous | |
First Copy Out Time B/W | 8 sec |
First Copy Out Time Colour | 10 sec |
Consumables Included | 1 x ink cartridge (black) - up to 800 pages - HP 937 , 1 x ink cartridge (cyan) - up to 420 pages - HP 937 , 1 x ink cartridge (magenta) - up to 420 pages - HP 937 , 1 x ink cartridge (yellow) - up to 420 pages - HP 937 |
Compliant Standards | BSMI, GS, IC CS-03, CCC, ANATEL, FCC CFR47 Part 15 B, EAC, ICASA, EN 61000-3-3:2013, CISPR 24:2010, EN 55024:2010, TIA-1096, EN 301 489-1, EN 61000-3-2:2014, CNC, IEC60950-1:2005, Second edition + Am1:2009 + Am2:2013, TIA-968-B, UL 62368-1 Second Edition, ICES-003 issue 6 Class B, CISPR 32:2012, EN 301 489-17, EN 55032:2012 Class B, SCT, IEC 62368-1: 2014 Second Edition, RED 2014/53/EU, EN 62368-1:2014+A11:2017, ES 203 021-2, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Dimensions & Weight | |
Width | 43.7 cm |
Depth | 42.18 cm |
Height | 31.83 cm |
Weight | 11.84 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 49.6 cm |
Shipping Depth | 37.7 cm |
Shipping Height | 48.9 cm |
Shipping Weight | 14.8 kg |
Environmental Parameters | |
Sound Emission | 61 dBA (operating) |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
