Print professional-quality colour for up to 50% lower cost per page than lasers with this web-connected printer.[1] Print via your wired or wireless network or on the go with HP ePrint - now you can print from virtually anywhere.[2],[3]
Print professional-quality colour for up to 50% lower cost per page than lasers.[1]
- Create professional colour documents for up to 50% lower cost per page than competitive lasers.[1]
- Print documents that resist fading, water and highlighter pen smearing with HP Officejet inks.[4],[5]
- Print at ISO (laser comparable) speeds of up to 20 ppm black, 16 ppm colour, using affordable, individual inks.
- Maximise your productivity and get better value for frequent printing with high capacity XL ink cartridges.[6]
Print wirelessly or on the go with a choice of mobile printing options.[2],[3]
- Discover the freedom of HP ePrint - now you can print from virtually anywhere.[3]
- Connect to your network wirelessly or with built-in Ethernet, or directly to your PC with Hi-speed USB.[2]
- Print e-mails, documents, web pages and more direct from your iPad®, iPhone® or iPod touch® with AirPrint™.[7]
- Print wirelessly direct from a smartphone and other mobile devices using HP mobile printing applications.[8]
Share high-productivity features between multiple users.
- Boost productivity - and save time and paper - with automatic two-sided printing.
- Use the intuitive control panel and graphic display to access print tools, check ink levels and more.
- Create double-sided flyers, borderless photos, impressive leaflets and other professional-looking materials.
- Enjoy reliable printing with minimal interruptions with 250-sheet paper tray, expandable to 500 sheets.[9]
[1] Majority of colour laser printers <€200 excluding VAT, March 2011. For details: www.hp.com/eur/ojfacts. OJ Pro ISO yield with highest-capacity cartridges based on continuous printing; see www.hp.com/go/learnaboutsupplies.
[2] Wireless performance is dependent upon physical environment and distance from access point. Wireless operations compatible with 2.4GHz routers only.
[3] Requires an Internet connection to the printer. Feature works with any connected Internet- and e-mail-capable device. Print times may vary. For a list of supported documents and image types, see www.hp.com/go/eprintcenter.
[4] Based on paper-industry predictions for acid-free papers and Original HP inks; colorant stability data at room temperature based on similar systems tested per ISO 11798 and ISO 18909.
[5] Based on HP internal testing, using paper with the ColorLok® logo.
[6] Not included, please purchase separately.
[7] Supports iOS 4.2 and later devices (iPad®, iPhone® 4, iPhone® 3GS, and 3rd and 4th generation iPod touch®) that support multitasking. AirPrint™ and iOS 4.2 and later devices require an 802.11 `wireless network' connection to the printer. AirPrint and the AirPrint Logo are trademarks of Apple® Inc. iPad, iPhone, and iPod touch are trademarks of Apple Inc., registered in the U.S. and other countries.
[8] Requires access to third party apps stores. See www.hp.com/go/mobile-printing-solutions for details of compatible devices.
[9] Optional 250-sheet paper tray not included; please purchase separately.
Print speed black (ISO, laser comparable) | Up to 20 ppm | Print quality black (best) | Up to 1200 x 600 dpi | Print quality color (best) | Up to 4800 x 1200 optimized dpi on HP Advanced Photo paper, 1200 x 1200 input dpi | Duty cycle (monthly, A4) | Up to 25,000 pages | Display | Iconic graphic display | Processor speed | 360 MHz ARM R4; 360 MHz ST231 PIE DSP | Memory, standard | 128 MB DDR3 | Print languages | HP PCL 3 GUI; HP PCL 3 Enhanced | Paper handling output, standard | 150-sheet output tray | Duplex printing | Automatic (standard) | Envelope input capacity | Up to 30 envelopes | Borderless printing | Yes (up to 8.5 x 11 in, 216 x 279 mm) | Media sizes supported | A4; A5; A6; B5(JIS); Envelope (DL, C5, C6, Chou #3, Chou #4); Card (Hagaki, Ofuku Hagaki) |
