This affordable HP LaserJet Pro MFP is easy to install and delivers crisp, clear documents. Print, copy and scan with one, compact device that fits neatly into small office spaces.
Product Description | HP LaserJet Pro MFP M125nw - multifunction printer - B/W | Device Type | Multifunction printer | Localisation | English, German, French, Italian, Spanish / Europe | Printing Technology | Laser (monochrome) | Monthly Duty Cycle (max) | 8000 pages | Recommended Monthly Volume | 250 - 2000 pages | Max Copying Speed | Up to 20 ppm | Max Copying Resolution | Up to 400 x 600 dpi | Max Printing Speed | Up to 20 ppm | Max Printing Resolution | Up to 600 x 600 dpi | Scanning | 1200 x 1200 dpi | Original Size | 216 x 279 mm (max) | Media Size | 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max) | Media Type | Transparencies, envelopes, plain paper, cards, labels | Standard Media Capacity | 150 sheets | Output Trays Capacity | 100 sheets | Connection Availability | Yes | Interface | USB 2.0, LAN, Wi-Fi(n) | AirPrint Enabled | Yes | Power | AC 230 V | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | EPEAT Silver, ENERGY STAR Qualified | Manufacturer Warranty | 1-year warranty |
General | |
Printing Technology | Laser - monochrome |
Display | 2 lines |
Memory | |
Standard Memory | 128 MB |
Max Supported Memory | 128 MB |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 99 |
Printing | |
Printer Drivers / Emulations | PCL |
Image Enhancement Technology | HP FastRes 1200 |
First Print Out Time B/W | 9.5 sec |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 x 1200 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 24-bit |
Document & Media Handling | |
Max Original Size | 216 x 279 mm |
Min Media Size | 76 x 127 mm |
Max Media Size | A4/Legal |
Min Media Weight | 60 g/m² |
Max Media Weight | 163 g/m² |
Supported Media Type | Transparencies, envelopes, plain paper, cards, labels |
Supported Media Sizes | Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), JIS B5 (182 x 257 mm), 76 x 127 mm |
Supported Envelope Sizes | US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm) |
Document & Media Handling Details | Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets |
Speed Details | Printing: up to 20 ppm (A4) - B/W , Copying: up to 20 ppm (A4) - B/W |
Connections | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 |
Security Protocols & Features | WEP, WPA, WPA2 |
Software Included | HP Toolbox |
Power | |
Voltage Required | AC 230 V |
Miscellaneous | |
Included Accessories | USB cable |
Consumables Included | 1 x toner cartridge (black) - up to 700 pages |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Environmental Standards | |
EPEAT Compliant | EPEAT Silver |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Dimensions & Weight (Shipping) | |
Shipping Width | 49.7 cm |
Shipping Depth | 35 cm |
Shipping Height | 33.2 cm |
Shipping Weight | 10.3 kg |
