Drive business results and produce outstanding print quality. Tackle large jobs and equip workgroups for success – wherever business leads. Easily manage and expand this ultra-fast, versatile printer and help reduce environmental impact.
Product Description | HP LaserJet Enterprise M606x - printer - B/W - laser | Printer Type | Workgroup printer - laser - B/W | Weight | 32.5 kg | Localisation | English, German, French, Italian, Spanish / Europe | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) | Min Media Size (Custom) | 76 mm x 127 mm | Max Media Size (Custom) | 216 mm x 356 mm | Print Speed | Up to 62 ppm - B/W - A4 (210 x 297 mm) , Up to 65 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 41 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 43 ipm - B/W duplex - ANSI A (Letter) (216 x 279 mm) | Max Resolution (B&W) | 1200 x 1200 dpi | Image Enhancement Technology | HP ImageRet 3600 / HP ProRes 1200 | Automatic Duplexing | Yes | Interface | USB 2.0, Gigabit LAN, Wi-Fi(n), NFC, USB 2.0 host | AirPrint Enabled | Yes | Processor | 1.2 GHz | RAM Installed (Max) | 512 MB (1.5 GB) - SDRAM - DIMM 90-pin | Flash Memory Installed (Max) | 4 GB | Language Simulation | PCL 5E, PostScript 3, PCL 6, PDF 1.7 | Media Type | Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, card stock, light-weight paper, punched paper, preprinted paper | Total Media Capacity | 1100 sheets | Media Handling | 2x 500-sheet input trays, 100-sheet multipurpose tray | Monthly Duty Cycle (max) | 275000 pages | Recommended Monthly Volume | 5000 - 20000 pages | Networking | Print server | Printer Features | Hardware integration pocket, Instant-on Technology | System Requirements | UNIX, Microsoft Windows XP SP3, Android, Microsoft Windows Vista (32/64 bits), Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), openSUSE 12.2, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Red Hat Fedora 18, openSUSE 12.3, Linux Mint 13, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, openSUSE 13.1, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x | Dimensions (WxDxH) | 42.5 cm x 53.7 cm x 52.1 cm |
General | |
Printer Type | Workgroup printer - laser - monochrome |
Printer | |
Built-in Devices | 4.3 inch LCD touch screen |
Connectivity Technology | Wireless |
PostScript Support | Standard |
First Print Out Time B/W | 7 sec |
Fonts Included | 105 x TrueType , 92 x PostScript 3 |
Processor | |
RAM | |
RAM Installed (Max) | 512 MB / 1.5 GB (max) |
Technology / Form Factor | SDRAM - DIMM 90-pin |
Slots Qty | 1 |
Empty Slots | 1 |
Flash Memory | |
Flash Memory | 4 GB |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, 215.9 x 330.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm) |
Envelope Sizes | US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm) |
Media Weight | 60 g/m² - 200 g/m² |
Media Feeders | 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , 2 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² |
Max Media Capacity | 3600 sheets |
Output Trays Capacity | 600 sheets |
Duty Cycle | |
Networking | |
Network Controller Name | HP Jetdirect |
Remote Management Protocol | SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, NDS, HTTPS, TFTP, IPPS, SLP |
Security Protocols & Features | Kerberos, LDAP, Apple Bonjour, IPsec, 802.1x, EAP-TLS, PEAP |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 |
Miscellaneous | |
Consumables Included | 1 x toner cartridge (black) - up to 10500 pages ISO/IEC 19752 |
Features | Security lock slot (cable lock sold separately) |
Compliant Standards | FCC Class A certified, UL, cUL, GS, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, EN 62479:2010, EMC 2004/108/EC, IEC 60950-1:2005, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011, ICES-003 issue 4, EN 55024:2010, EN 55022:2010 Class A, CISPR 22:2008 |
Security Slot Type | Kensington security slot |
Power | |
Power Device | Power supply - internal |
Frequency Required | 50/60 Hz |
Power Consumption Operational | 840 Watt |
Power Consumption Sleep | 3.7 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | UNIX, Microsoft Windows XP SP3, Android, Microsoft Windows Vista (32/64 bits), Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), openSUSE 12.2, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Red Hat Fedora 18, openSUSE 12.3, Linux Mint 13, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, openSUSE 13.1, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x |
Environmental Standards | |
Blue Angel | Yes |
ENERGY STAR | Yes |
Environmental Parameters | |
Min Operating Temperature | 15 °C |
Max Operating Temperature | 32 °C |
Humidity Range Operating | 10 - 80% |
Sound Emission (Idle) | 27 dBA |
Sound Emission (Operating) | 56 dBA |
Dimensions & Weight | |
Width | 42.5 cm |
Depth | 53.7 cm |
Height | 52.1 cm |
Weight | 32.5 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 75 cm |
Depth (Shipping) | 58.9 cm |
Height (Shipping) | 49.9 cm |
Weight (Shipping) | 38.4 kg |
