Enable large-volume professional-quality colour printing on a wide range of paper sizes up to A3, with paper capacity up to 4,350 sheets. Preview and edit scanning jobs. Centrally manage printing policies. Safeguard sensitive business information.
Product Description | HP Color LaserJet Enterprise MFP M775dn - multifunction printer - colour | Device Type | Multifunction printer | Copier Type | Digital | Localisation | English, German, French, Italian, Spanish / Europe | Printing Technology | Laser (colour) | Monthly Duty Cycle (max) | 120000 impressions | Recommended Monthly Volume | 2500 - 7500 pages | Max Copying Speed | Up to 30 ppm (mono) / up to 30 ppm (colour) | Max Copying Resolution | Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour) | Max Printing Speed | Up to 30 ppm (mono) / up to 30 ppm (colour) | Max Printing Resolution | Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour) | Scanning | 600 x 600 dpi | Display | 8.07" | Original Size | 101.6 x 152.4 mm (min) - A3/Ledger (297 x 432 mm) (max) | Original Type | Sheets | Document Feeder Capacity | 100 sheets | Media Size | 76 x 127 mm (min) - 320 x 470 mm (max) | Media Type | Transparencies, envelopes, plain paper, labels, recycled paper, photo paper, bond paper, film, heavy-weight paper, card stock | Standard Media Capacity | 350 sheets | Bypass Feeder Capacity | 100 sheets | Output Trays Capacity | 250 sheets | Automatic Duplexing | Yes (copying) Yes (printing) | Connection Availability | Yes | Interface | USB 2.0, Gigabit LAN, USB host, 2 x USB host (internal) | AirPrint Enabled | Yes | Office Machine Features | Document send function, save to USB flash drive, scan to e-mail, scan to network, Hardware Integration Pocket, automatic paper sensor, Foreign Interface Harness (FIH) | Power | AC 230 V (50/60Hz) | Dimensions (WxDxH) | 59.2 cm x 63.9 cm x 59.5 cm | Weight | 63.7 kg | Environmental Standards | EPEAT Silver, ENERGY STAR Qualified |
General | |
Printing Technology | Laser - colour |
Display Diagonal Size | 8.07" |
Display Features | Touch screen |
Memory | |
Standard Memory | 1536 MB 1.5 GB |
Max Supported Memory | 1536 MB 1.5 GB |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 9999 |
Automatic Duplexing | Yes |
Copying Features | Auto colour select |
Printing | |
Printer Drivers / Emulations | PCL 6, PostScript 3, PCL 5c, PDF 1.4 |
Image Enhancement Technology | HP ImageREt 3600 |
First Print Out Time B/W | 10.5 sec |
First Print Out Time Colour | 10.5 sec |
Scanning | |
Scan Element | CCD |
Optical Resolution | 600 x 600 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 24-bit |
Document & Media Handling | |
Min Original Size | 101.6 x 152.4 mm |
Max Original Size | A3/Ledger (297 x 432 mm) |
Min Media Size | 76 x 127 mm |
Max Media Size | A3/Ledger |
Min Media Weight | 49 g/m² |
Max Media Weight | 120 g/m² |
Supported Media Type | Transparencies, envelopes, plain paper, labels, recycled paper, photo paper, bond paper, film, heavy-weight paper, card stock |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), ANSI B (Ledger) (279 x 432 mm), ARCH B (304.8 x 457.2 mm), Folio (216 x 330 mm), 297 x 432 mm, 148 x 182 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), SRA4 (225 x 320 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 76 x 127 mm, RA3 (305 x 430 mm), 127 x 177.8 mm, 320 x 470 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm) |
Supported Envelope Sizes | US No 10 (104.7 x 241.3 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm) |
Document & Media Handling Details | Output tray - 250 sheets , Bypass tray - 100 sheets size: 76 x 127 mm - 320 x 470 mm weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: 148 x 182 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 220 g/m² , ADF - 100 sheets size: 101.6 x 152.4 mm - A3/Ledger (297 x 432 mm) |
Speed Details | Printing: up to 30 ppm (A4) - B/W normal , Printing: up to 30 ppm (A4) - colour normal , Copying: up to 30 ppm (A4) - B/W normal , Copying: up to 30 ppm (A4) - colour normal , Scanning: up to 30 ppm (A4) - B/W normal , Scanning: up to 30 ppm (A4) - colour normal |
Connections | |
Interfaces | 1 x USB 2.0 , 1 x USB host , 2 x USB host (internal) , 1 x Gigabit LAN |
Operating System Support | UNIX, Linux, MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Windows 8 |
Software Included | Drivers & Utilities |
Power | |
Voltage Required | AC 230 V (50/60Hz) |
Power Consumption Operational | 703 Watt |
Power Consumption Standby | 85 Watt |
Power Consumption Sleep | 14.8 Watt |
Miscellaneous | |
Included Accessories | Phone cable |
Consumables Included | 1 x toner cartridge (black) - up to 13500 pages , 1 x toner cartridge (cyan) - up to 16000 pages , 1 x toner cartridge (magenta) - up to 16000 pages , 1 x toner cartridge (yellow) - up to 16000 pages |
Compliant Standards | FCC Class A certified, UL, cUL, GS, ICES-003, EN55024, EN55022 Class A, CISPR 22, EMC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1, LVD, GB 9254-2008, EN 61000-3-2:2006, EN 61000-3-3:2008, GB 17625.1-2003 EMC |
Environmental Standards | |
EPEAT Compliant | EPEAT Silver |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Width | 59.2 cm |
Depth | 63.9 cm |
Height | 59.5 cm |
Weight | 63.7 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 76 cm |
Shipping Depth | 74.5 cm |
Shipping Height | 83.2 cm |
Shipping Weight | 76.5 kg |
Environmental Parameters | |
Sound Emission | 53 dBA (operating) |
Min Operating Temperature | 15 °C |
Max Operating Temperature | 27 °C |
Humidity Range Operating | 10 - 70% |
