Low running costs
The WorkForce Pro WF-5110DW has an up to 50 percent lower cost per page than competitive colour lasers , saving you money as you take advantage of this printer's high capacity ink cartridges of up to 4,000 pages . And there are fewer parts to replace than a laser.
Ecological
The WF-5110DW uses up to 80 percent less power than competitive colour lasers thanks, in part, to its no heat technology. No ozone gases are emitted, and an improved quiet print mode and no fan noise during or after printing makes it ideal for the work environment.
Save time
This efficient business printer is faster than a laser on typical print jobs , with print speeds of up to 34ppm in mono and 30ppm in colour, or 20ppm ISO print speed in both . Its high paper capacity of 580 sheets means less time is spent refilling, and a monthly duty cycle of up to 35,000 pages4means you can print lots in confidence.
Built for business
PrecisionCore technology powers the output quality that Epson is known for, at the speeds required for office, commercial and industrial printing. Prints dry fast thanks to the DURABrite Ultra ink. Print securely with Email Print for Enterprise. Epson Connect5 lets you easily print from smartphones, tablets and more, and its Wi-Fi Direct capability lets you print from supported wireless devices without connecting to a router.
Product Description | Epson WorkForce Pro WF-5110DW - printer - colour - ink-jet | Printer Type | Workgroup printer - ink-jet - colour | Weight | 11.3 kg | Inkjet Technology | Epson PrecisionCore | Ink Palette Supported (Colours) | 4-ink - cyan, magenta, yellow, black | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) | Print Speed | Up to 34 ppm - B/W , Up to 30 ppm - colour , Up to 20 ppm - B/W (ISO/IEC 24734) , Up to 20 ppm - colour (ISO/IEC 24734) , Up to 11 ppm - B/W duplex (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 11 ppm - colour duplex (ISO/IEC 24734) - A4 (210 x 297 mm) | Max Resolution (B&W) | 4800 x 1200 dpi | Max Resolution (Colour) | 4800 x 1200 dpi | Automatic Duplexing | Yes | Interface | USB 2.0, Gigabit LAN, Wi-Fi(n), USB host | AirPrint Enabled | Yes | Language Simulation | EPSON ESC/P Raster, Windows GDI driver | Media Type | Envelopes, plain paper | Total Media Capacity | 330 sheets | Media Handling | 250-sheet input tray, 80-sheet multipurpose tray | Monthly Duty Cycle (max) | 35000 pages | Networking | Print server | System Requirements | Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Apple MacOS X 10.6 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition | Dimensions (WxDxH) | 46.1 cm x 44.2 cm x 28.4 cm |
