The All-In-One that handles everything with ease
PIXMA MX375 is an All-In-One with fax that delivers quality prints. With a built-in 30-sheet ADF, full suite of software it's both versatile and affordable. Compact design with FastFront.
Quality results for home and office
This affordable All-In-One lets you copy, print, scan and fax with ease. Canon's FINE ink technology, with microscopic ink droplets, plus a resolution of 4800 x 1200 dpi ensures quality printing everytime. From vivid and glossy graphics to business documents of outstanding clarity, the printer is ideal for use at home or in a small office.
Productivity booster
For maximum productivity, a fully-integrated 30-sheet Automatic Document Feeder makes scanning, copying or faxing of large documents easy and fast.
Do more for less, faster
Enjoy print speeds, of 8.7 ipm in mono or 5.0 ipm in colour. A 10x15 cm borderless photo is printed in approximately 46 seconds, while an A4 page copies in just 23 seconds. Canon's Dual Colour Gamut Processing technology enables great quality photocopying with no waiting around.
Value for money
For further savings you can print more for less, with the high yield Canon XL cartridges, which offer 50% lower cost per page.
Space-saving design and easy-to-use
The compact FastFront design means paper and ink cartridges can be loaded from the front of the printer - making it easier to fit into a busy work space. Quick Start functionality means there is no need to wait for the printer to `warm up'. Operation is almost instantaneous from the moment the power is switched on, ensuring that the user can perform actions almost straight away.
Fast faxing
Super G3 faxing is fast and reliable. The PIXMA MX375 can send faxes directly from the PC without printing the document first. For advanced security you can prevent users accidentally sending faxes to the wrong number.
Intelligent software
Take control of your web printing, easily combining content from several websites with Easy-WebPrint EX. Automatically optimising the quality and legibility of scanned documents is simple with Auto Document Fix. For additional security MP Navigator EX adds passwords to PDFs that restrict who can edit or print sensitive documents.
All-In-One with fax and 30-sheet ADF
Up to 4800dpi, min. 2pl quality
ISO ESAT 8.7 ipm mono/5.0 ipm colour
ISO A4 Copy: 23 seconds
Easy-WebPrint EX for efficient web printing
Auto Document Fix enhancement
Full HD Movie Print
Product Description | Canon PIXMA MX375 - multifunction printer - colour | Device Type | Multifunction printer | Copier Type | Digital | Fax Type | Super G3 - plain paper | Printing Technology | Ink-jet (colour) | Inkjet Technology | Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink | Max Copying Speed | 3.4 ppm (colour) | Max Printing Speed | Up to 8.7 ipm (mono) / up to 5 ipm (colour) | Max Printing Resolution | 4800 x 1200 dpi (colour) | Max Fax Transmission Speed | 33.6 Kbps | Data Compression System | MH, MR, MMR, JPEG | Fax Resolutions | 300 x 300 dpi, 200 x 200 dpi | Scanning | 1200 x 2400 dpi | Original Size | A4 (210 x 297 mm), Legal (216 x 356 mm) (max) | Original Type | Sheets | Document Feeder Capacity | 30 sheets | Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) (max) | Media Type | Envelopes, plain paper, photo paper | Standard Media Capacity | 100 sheets | Connection Availability | Yes | Interface | USB 2.0 | Power | AC 110/230 V (50/60Hz) | Dimensions (WxDxH) | 45.8 cm x 38.5 cm x 20 cm | Weight | 8.4 kg |
General | |
Fax Type | Plain paper |
Printing Technology | Ink-jet - colour - photo |
Copying | |
Grayscale Half-Tones | 256 |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 99 |
Copying Features | 2 on 1, BorderFree, 4 on 1, fit to page, Preset Copy Ratios, Frame Erase Copy, collation copy |
Printing | |
Inkjet Technology | Canon FINE (Full-lithography inkjet Nozzle Engineering) |
Colour | 4-ink |
Minimum Ink Droplet Size | 2 pl |
Ink Type | Canon ChromaLife100 |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 x 2400 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 24-bit |
Colour Depth (Internal) | 48-bit |
Fax Machine | |
Compatibility | Super G3 |
Max Transmission Speed | 33.6 Kbps |
Total Memory Capacity | Up to 50 pages |
Fax Machine Features | |
Error Correction Mode (ECM) | Yes |
Speed Dialing | 20 station(s) |
Telephone / Fax Switch | Yes |
Features | Activity report, automatic redialing, answering machine interface, group dialling, remote reception, Dual Access |
Document & Media Handling | |
Max Original Size | A4 (210 x 297 mm), Legal (216 x 356 mm) |
Max Media Size | Legal |
Min Media Weight | 64 g/m² |
Max Media Weight | 300 g/m² |
Supported Media Type | Envelopes, plain paper, photo paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm |
Supported Envelope Sizes | International DL (110 x 220 mm), Com-10 (105 x 241 mm) |
Borderless Photo Sizes | ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm |
Document & Media Handling Details | ADF - 30 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) , Input tray - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) |
Speed Details | Printing: up to 8.7 ipm - B/W , Printing: up to 5 ipm - colour , Copying: up to 3.4 ipm - colour , Printing: 46 sec (10 x 15 cm (4"x6")) - photo |
Connections | |
Interfaces | 1 x USB 2.0 |
Operating System Support | MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), MS Windows XP SP2, Apple Mac OS X 10.5.8 - 10.7 |
Software Included | Drivers & Utilities, Canon Easy-WebPrint EX, Fax Speed Dial Utility, Canon Easy-PhotoPrint EX, Canon MP Navigator EX, Canon Solution Menu EX |
Power | |
Voltage Required | AC 110/230 V (50/60Hz) |
Power Consumption Operational | 14 Watt |
Power Consumption Standby | 1.6 Watt |
Power Consumption Sleep | 0.4 Watt |
Miscellaneous | |
First Copy Out Time Colour | 23 sec |
Consumables Included | 1 x ink cartridge (black) - up to 180 pages - Canon PG-540 , 1 x ink cartridge (colour) - up to 180 pages - Canon CL-541 |
Dimensions & Weight | |
Width | 45.8 cm |
Depth | 38.5 cm |
Height | 20 cm |
Weight | 8.4 kg |
Environmental Parameters | |
Sound Emission | 42.5 dB (operating) |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% |
