WD Purple Surveillance Storage: 3.5-inch, SATA 6 Gb/s, IntelliPower - The evolution of surveillance.
WD Purple Surveillance Storage offers exclusive AllFrame technology to bring you premium reliability and peace-of-mind when installing your home or small to medium business security system. WD Purple's exclusive firmware upgrades work with ATA streaming to reduce error pixilation and video interruptions that occur when desktop hard drives are incorrectly used as storage in security systems. WD Purple Surveillance Storage is built for 24/7, always-on, high-definition surveillance security systems that use up to eight hard drives and up to 32 cameras.
Choose a drive that is designed and engineered for home and business surveillance systems and enjoy the peace-of-mind you can only get from a surveillance-class hard drive.
WD Purple Surveillance Hard Drive Features
Ideal For
Compatibility
Warranty
Product Description | WD Purple WD40PURX - hard drive - 4 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 4 TB | Form Factor | 3.5" x 1/3H | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 64 MB | Features | Time-Limited Error Recovery (TLER), IntelliSeek, IntelliPower, Advanced Format technology, AllFrame, surveillance system compatible, S.M.A.R.T. | Dimensions (WxDxH) | 101.6 mm x 147 mm x 26.1 mm | Weight | 680 g | Manufacturer Warranty | 3-year warranty | Designed For | My Cloud EX2; EX4 |
General | |
Device Type | Hard drive - internal |
Capacity | 4 TB |
Width | 101.6 mm |
Depth | 147 mm |
Height | 26.1 mm |
Weight | 680 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 150 MBps |
Reliability | |
MTBF | 1,000,000 hour(s) |
Non-Recoverable Errors | 10 per 10^14 |
Load / Unload Cycles | 300,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s - 7 pin Serial ATA |
Compatible Bay | 3.5" x 1/3H |
Power | |
Power Consumption | 5.1 Watt (read) , 5.1 Watt (write) , 4.5 Watt (idle) , 0.5 Watt (standby) , 0.5 Watt (sleep) |
Software & System Requirements | |
OS Required | Apple MacOS, Microsoft Windows 7 / Windows 8 |
Miscellaneous | |
Compliant Standards | ICES-003 Class B, RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 65 °C |
Shock Tolerance | 65 g @ 2ms (operating) / 250 g @ 2ms (non-operating) |
Sound Emission | 25 dBA |
Compatibility Information | |
Designed For | WD My Cloud EX2 , WD My Cloud EX4 |
