ITEM | QTY | PRICE |
HP P19b G4 19" 1366x768 5ms VGA...
2 | £276.00 |
The Power of Agility for home, SOHO and SMB NAS enclosures. IronWolf is designed for everything NAS. Get used to tough, ready and scalable 24/7 performance that can handle multi-drive environments with a wide range of capacities.
Product Description | Seagate IronWolf ST4000VN008 - hard drive - 4 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 4 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 64 MB | Spindle Speed | 5900 rpm | Features | Halogen Free, NAS compatible, 24x7 availability, Dual-Plane Balance, Error Recovery Control | Dimensions (WxDxH) | 101.6 mm x 146.99 mm x 26.11 mm | Weight | 610 g | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 4 TB |
Width | 101.6 mm |
Depth | 146.99 mm |
Height | 26.11 mm |
Weight | 610 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 180 MBps |
Reliability | |
MTBF | 1,000,000 hours |
24x7 Operation | Yes |
Non-Recoverable Errors | 1 per 10^14 |
Load / Unload Cycles | 600,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 2 Watt (start) , 4.8 Watt (active) , 3.95 Watt (idle) , 0.5 Watt (standby) , 0.5 Watt (sleep) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 70 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Shock Tolerance (operating) | 80 g @ 2 ms |
Shock Tolerance (non-operating) | 300 g @ 2 ms |
