Make 10Gb Ethernet connections with PoE support. This high quality 14ft Cat 6a cable (STP) ensures dependable Ethernet connectivity, supporting 10 Gigabit performance up to 500 MHz - double that of standard Category 6 cable and five times the bandwidth offered by Cat5 - an excellent choice for Power over Ethernet (PoE) applications.
All of Cat 6a cables are constructed of high quality 25 AWG shielded copper pairs to protect against noise and EMI/RFI interference, ensuring that Cat6a cables are more than suitable for 10GBase-T Ethernet networks and Power over Ethernet applications.
StarTech.com Cat 6a patch cables provide end-to-end solutions that are tested for compliance with all TIA/ETL-568-B2.10 Category 6, UL 444 and ROHS 2002/95/EC specifications.
Product Description | StarTech.com 14ft CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Blue, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (C6ASPAT14BL) - patch cable - 4.3 m - blue | Type | Patch cable - CAT 6a | Technology | Shielded twisted pair (STP) | Wiring Scheme | T568B | Shielding Material | Aluminium-polyester foil | Features | Molded | Length | 4.3 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Blue | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Patch cable - CAT 6a |
Jacket Material | PVC |
American Wire Gauge (AWG) | 26 |
Features | Molded |
Length | 4.3 m |
Colour | Blue |
Connectivity | |
Miscellaneous | |
Compliant Standards | UL 444, RoHS - up to 500 MHz |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
