100% COPPER WIRING: The CAT6a Ethernet cables are built with 100% copper wiring to prevent weak power delivery and equipment damage, compared to copper-clad aluminum wire cables
QUALITY PERFORMANCE: Built for high performance, each CAT6a patch cable features 26 AWG copper wiring and is tested to comply with ANSI/TIA 568 C.2 CAT6a requirements
EASY INSTALLATION: The 7.5 m network cords feature snagless connectors and molded boots to protect the RJ-45 clips from cable damage during installations and to ensure a secure network connection
26 AWG WIRE: All shielded CAT6a STP cables are built with 26 AWG wiring to ensure peak performance for your demanding Ethernet applications
Product Description | StarTech.com 7.5m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Black, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT750CMBK) - patch cable - 7.5 m - black | Type | Patch cable - CAT 6a | Technology | Shielded twisted pair (STP) | Shielding Material | Aluminium-polyester foil | Wires per Cable | 8 wires | Features | Molded, snagless, RFI/EMI shielding | Length | 7.5 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Patch cable - CAT 6a |
Jacket Material | PVC |
American Wire Gauge (AWG) | 26 |
Pairs per Cable | 4 pairs |
Plated Connector | Gold |
Length | 7.5 m |
Weight | 290 g |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS, REACH, ANSI/TIA-568-C.2, CMG - up to 500 MHz |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
