Small office/home office (SOHO) businesses comprise over 60 percent of high average monthly print volume (AMPV) users. These cost-conscious businesses demand the same fast, high-quality deliverables as enterprises, but they don't want to sacrifice print quality for price. Plus, they require anytime, anywhere access to work-related information.
Samsung Color Multifunction Xpress C480 series printers combine ease of operation with high performance at an affordable price, ideal for today's cost-conscious SOHO work anywhere, anytime business environment.
Product Description | Samsung Xpress C480FW - multifunction printer - colour | Device Type | Multifunction printer | Fax Type | Plain paper | Printing Technology | Laser (colour) | Max Copying Speed | Up to 18 ppm (mono) / up to 4 ppm (colour) | Max Printing Speed | Up to 18 ppm (mono) / up to 4 ppm (colour) | Max Printing Resolution | Up to 600 x 600 dpi (mono) / up to 2400 x 600 dpi (colour) | Scanning | 1200 x 1200 dpi | Original Type | Sheets | Document Feeder Capacity | 40 sheets | Media Size | A4 (210 x 297 mm) (max) | Media Type | Plain paper | Standard Media Capacity | 150 sheets | Output Trays Capacity | 50 sheets | Connection Availability | Yes | Interface | USB 2.0, LAN, USB host, Wi-Fi, NFC | AirPrint Enabled | Yes | Office Machine Features | Scan to e-mail, Rendering Engine for Clean Page (RECP) technology, Samsung Cloud Print ready | Dimensions (WxDxH) | 50.1 cm x 46.6 cm x 44 cm | Environmental Standards | ENERGY STAR Qualified |
General | |
Printing Technology | Laser - colour |
Display | 2 lines |
Memory | |
Standard Memory | 128 MB |
Copying | |
Printing | |
Printer Drivers / Emulations | PostScript 3, PCL 5c, SPLC, PCL 6C, PCLm, URF, PWG |
First Print Out Time B/W | 14 sec |
First Print Out Time Colour | 26 sec |
Scanning | |
Optical Resolution | 1200 x 1200 dpi |
Interpolated Resolution | 4800 x 4800 dpi |
Document & Media Handling | |
Max Media Size | A4 |
Supported Media Type | Plain paper |
Supported Media Sizes | A4 (210 x 297 mm) |
Document & Media Handling Details | Input tray - 150 sheets , Output tray - 50 sheets , ADF - 40 sheets |
Speed Details | Printing: up to 18 ppm (A4) - B/W , Printing: up to 4 ppm (A4) - colour , Copying: up to 18 ppm (A4) - B/W , Copying: up to 4 ppm (A4) - colour |
Connections | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A |
Security Protocols & Features | Wi-Fi Direct |
Operating System Support | Android, iOS, Windows Phone |
Miscellaneous | |
Consumables Included | 1 x toner cartridge (black) - up to 700 pages , 1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages , 1 x toner cartridge (yellow) - up to 500 pages |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Width | 50.1 cm |
Depth | 46.6 cm |
Height | 44 cm |
