Colour your world with light
The Philips friends of hue LightStrips starter kit lets you create ideal mood lighting at home with your smartphone or devices. Create that extra dimension on architectural features or simply behind objects. Bend, shape or flex — it's your choice.
Wireless connectivity
Match your light to the moment
Fits with every interior perfectly
Create your own light settings
Use your favourite picture to generate the perfect colour scene for special occasions. Go back in time and relive those moments by uploading your own picture and tuning the lights accordingly. Add up to 50 lights to every setting, and recall with a simple tap of the finger.
Light dynamics
The hue ecosystem is fully open for developers. There are an ever-growing number of applications being developed for hue within this community. This has resulted in creative and dynamic lighting schemes opening possibilities of syncing your lights to your favourite music, to get the party kicking.
Product Description | Philips Hue Lightstrip Plus - light strip - LED |
General | |
Product Type | Light strip |
Light Bulb | |
Type | LED |
