Zonal Color Control - make the most of 50-section addressable color zones, to suit every mood or scenario setting Extra White LEDs - act as general lights, strengthening the practicability of the colourful Wi-Fi light strip Fancy Lighting Effects - amuse yourself with well-designed animated lighting effects, available on Tapo App Music Sync - adds more vibe by emitting dynamic lights, parallel with the surrounding music beat Apple HomeKit Supported - control your light strip with Siri using Apple HomeKit Surface Coating-stays durable, tidy, and complete, thanks to the high-quality PU coating on its surface. Compatible with your smart voice assistants, including Alexa and Google Assistant Easy Setup - attach the Light Strip with 3M Adhesive on desired spots, connect it to Wi-Fi and configure it via App
Product Description | Tapo L930-10 - light strip - LED - 24 W - RGBW light - 2500-6500 K (pack of 2) | Product Type | Light strip | Light Source Type | LED | Packaged Quantity | 2 (specifications are for single item) | Usage Modes | Music sync, away | Wattage | 24 W | Colour of Illumination | RGBW light | Colour Temperature | 2500-6500 K | Luminous Power | 2000 lumens | Luminous Power per Length | 200 lumens/m | Dimmable | Yes | Intelligent Assistant | Google Assistant, Alexa - indirect | Platform | Apple HomeKit | Communications Technology | Wi-Fi | Voltage Required | AC 100 - 240 V | Frequency Required | 50/60 Hz |
General | |
Features | Flexible, 3M adhesive tape mounting, cuttable, app-controlled, lighting schedules, Wi-Fi (2.4 GHz) controlled, power on/off timer, voice control, 1 - 100% dimmable, 50 colour zones, 2 strips from 1 controller |
Light Source | |
Type | LED |
Built-in LED Lamp | Yes |
Wattage | 24 W |
Colour Rendering Index | 80 |
Warm-Up Time | 1 sec |
Dimmable | Yes |
Lifetime | 25000 hours |
Features | Colour changing LED, 16 million changeable colours, RGB colour changing control, white LED |
Power Requirements | |
Power Consumption Stand by | 0.4 Watt |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub | Not needed |
Compatible Application | Tapo app |
Supported Host Device Platform | iOS, Android |
Intelligent Assistant | Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Product Material | Polyurethane (PU) |
Included Accessories | Power adapter, controller, mounting adhesive |
Package | Box |
Compliant Standards | VCCI, BSMI, IC, FCC, RoHS, NCC, RCM, JRF, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Dimensions & Weight | |
Width | 1 cm |
Height | 0.3 cm |
Length | 5 m |
Environmental Parameters | |
Min Operating Temperature | -15 °C |
Max Operating Temperature | 40 °C |
