Looking for a portable mouse that helps you get things done? Sculpt Touch Mouse saves time in long documents and works virtually anywhere, with no cables or transceivers to connect. And it's designed to fit comfortably in either hand.
The four-way touch scrolling pad on the Sculpt Touch Mouse lets you breeze up and down, left and right, and through windows and documents with just the swipe of your finger. While you scroll, you'll feel the nice surprise of tactile feedback.
Product Description | Microsoft Sculpt Touch Mouse - mouse - Bluetooth - storm grey | Device Type | Mouse | Connectivity Technology | Wireless - Bluetooth | Colour | Storm grey | Orientation | Right and left-handed | Dimensions (WxDxH) | 6.5 cm x 9.55 cm x 3.3 cm | Weight | 111 g | Movement Detection Technology | Optical | Buttons Qty | 3 | Movement Resolution | 1000 dpi | Performance | 8000 fps | Features | Programmable buttons, touch-sensitive scroll, Microsoft BlueTrack Technology | Battery | 2 x AAA type | OS Required | Microsoft Windows 7, Windows 8, Apple MacOS X 10.6 - 10.7 | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 3-year warranty |
General | |
Width | 6.5 cm |
Depth | 9.55 cm |
Height | 3.3 cm |
Weight | 111 g |
Input Device | |
Connectivity Technology | Wireless |
Interface | Bluetooth |
Max Operating Distance | Up to 10 m |
Buttons Qty | 3 |
Miscellaneous | |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Battery | |
Type | AAA type |
Technology | Alkaline |
Installed Qty | 2 |
Run Time (Up To) | 9 months |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 80% (non-condensing) |
