ITEM | QTY | PRICE |
Lenovo ThinkPad USB 3.0 Secure HDD-500GB
3 | £515.19 |
Crucial 16GB DDR4 3200 MHz DIMM CL22...
4 | £136.20 |
HP HP 305 2-PACK TRI-COLOR/BLACK
4 | £77.88 |
MX Keys wireless keyboard, Master 3S wireless mouse, and palm rest combo.
Product Description | Logitech MX Keys Combo for Business - keyboard and mouse set - QWERTY - UK - graphite Input Device | Device Type | Keyboard and mouse set | Backlit | Yes | Interface | Bluetooth LE | Wireless Receiver | Logitech Logi Bolt USB receiver | Connectivity Technology | Wireless | Localization and Layout | QWERTY UK | Keys Qty | 108 | Hot Keys Function | Multimedia, mute, Easy-Switch, PerfectStroke | Keys Style | Scissors | Numeric Keypad | Yes | Pointing Device | Mouse - wireless - optical - right-handed | Buttons Qty | 7 | Colour | Graphite | Manufacturer Warranty | 2-year warranty |
General | |
Backlit | Yes |
Max Operating Distance | Up to 10 m |
Dimensions (WxDxH) / Weight | Keyboard: 43.02 cm x 13.163 cm x 2.05 cm / 810 g , Mouse: 8.43 cm x 12.49 cm x 5.1 cm / 141 g , Palm rest: 42 cm x 6.4 cm x 0.8 cm / 180 g |
Type | Wireless |
Keyboard Name | Logitech MX Keys for Business |
Keys Qty | 108 |
Region | United Kingdom, Ireland |
Palm Rest | Yes |
Features | Numeric keypad |
Pointing Device | |
Type | Mouse - wireless |
Pointing Device Name | Logitech MX Master 3S for Business |
Buttons Qty | 7 |
Thumb Buttons Qty | 2 |
Movement Detection Technology | Optical |
Movement Resolution | 8000 dpi |
Batteries: | Lithium polymer |
Orientation | Right-handed |
Miscellaneous | |
Colour | Graphite |
Included Accessories | Palm rest |
MTBF | 150,000 hours |
Key Life Span | 10 million clicks |
Software & System Requirements | |
OS Required | Linux, Google Chrome OS, Android 9.0 (Pie) or later, Apple iOS 14 or later, Apple iPadOS 14 or later, Windows 10 / 11 or later, Apple macOS 11 or later |
Battery | |
Type | Rechargeable |
Technology | Lithium polymer |
Run Time (Up To) | 10 days |
Dimensions & Weight (Shipping) | |
Shipping Width | 45.2 cm |
Shipping Depth | 14.6 cm |
Shipping Height | 7.5 cm |
Shipping Weight | 1.56 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Customer return - item has been used and shows signs of use very slight in dent on mouse thumb rest where thumb nail has put an indent on item.
Ref: HFS8 048659 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£145.95
