A full-size, wireless laser mouse with more comfort and extra controls so you can do more, more easily.
A nice grip
With its contoured shape, soft rubber grips and handy controls, this full-size, wireless laser mouse M510 delivers the comfort and control you need to do more, more easily.
Two-year battery life
It practically eliminates battery hassles. An On/Off switch and smart sleep mode extend battery life, while an indicator light eliminates surprises.
Side-to-side scrolling plus zoom
The power is in your hands. You can scroll side-to-side in documents or zoom in and out of photos and spreadsheets with a flick of your finger.
Laser tracking
Laser precision means you'll enjoy smoother tracking on just about any surface.
Logitech Unifying receiver
The tiny receiver stays in your laptop. Plus, you can easily add a compatible wireless mouse or keyboard--without the hassle of multiple USB receivers.
Programmable controls
You can configure the controls to make them to do exactly what you want like switching applications, opening browser windows or jump to full screen while watching videos.
Back/Forward buttons
Moving quickly through documents or browsing your favorite Web sites is a breeze, especially for right-handers-- with buttons conveniently located under your thumb.
Product Description | Logitech M510 - mouse - 2.4 GHz - black | Device Type | Mouse | Connectivity Technology | Wireless - 2.4 GHz | Colour | Black | Orientation | Right-handed | Wireless Receiver | USB wireless receiver | Movement Detection Technology | Laser | Buttons Qty | 5 | Features | Programmable buttons, zoom wheel, scrolling wheel, on/off power switch | Battery | 2 x AA type | OS Required | Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7 | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 3-year warranty |
General | |
Colour | Black |
Input Device | |
Connectivity Technology | Wireless |
Interface | 2.4 GHz |
Buttons Qty | 5 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Battery | |
Type | AA type |
Installed Qty | 2 |
Run Time (Up To) | 2 years |
Software / System Requirements | |
Additional Requirements | USB port |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
