The world's fastest gaming mouse. Whether you're lining up a headshot or dodging heavy fire, Hyperion Fury offers the blazing-fast tracking and pinpoint accuracy you need.
Product Description | Logitech Hyperion Fury G402 - mouse - USB | Device Type | Mouse | Connectivity Technology | Wired - USB | Orientation | Right-handed | Dimensions (WxDxH) | 7.2 cm x 13.6 cm x 4.1 cm | Weight | 144 g | Buttons Qty | 8 | Movement Resolution | 4000 dpi | Performance | 1 ms response time, 16 G maximum acceleration, 500+ inches per second, realtime sensitivity switching 240 - 4000 dpi | Features | Programmable buttons, rubber side grips, on-the-fly DPI switching with 4 stage LED light indicator, Fusion Engine, ARM 32-bit processor | OS Required | Microsoft Windows Vista / 7 / 8 / 8.1 | Manufacturer Warranty | 2-year warranty |
General | |
Width | 7.2 cm |
Depth | 13.6 cm |
Height | 4.1 cm |
Weight | 144 g |
Input Device | |
Connectivity Technology | Wired |
Interface | USB |
Buttons Qty | 8 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
