The difference between winning and losing in today's games isn't measured in meters or seconds, but micrometers and milliseconds. That's why Logitech G created the pro gaming mouse. Its lightweight body and optical gaming sensor are engineered for the unprecedented speed and precision aiming needed at the highest level of esport competition.
Consistent, pixel-precise accuracy makes a critical difference in high-stakes competitive gameplay. The PMW3366 delivers a level of precision widely considered to be the best by enthusiasts and professionals alike. With zero smoothing, filtering or acceleration across the entire DPI range (200-12,000DPI), it provides exceptional tracking accuracy and consistent responsiveness at any speed.
Product Description | Logitech G Pro - mouse - USB | Device Type | Mouse | Connectivity Technology | Wired - USB | Dimensions (WxDxH) | 6.215 cm x 11.66 cm x 3.82 cm | Weight | 129.5 g | Movement Detection Technology | Optical | Buttons Qty | 6 | Movement Resolution | 12000 dpi | Performance | 40 G maximum acceleration, realtime sensitivity switching 200 - 12000 dpi, 300 inches per second | Features | Scrolling wheel, built-in flash memory, 6 programmable buttons, RGB colour LED, Pixart PMW 3366 optical gaming sensor | OS Required | Microsoft Windows 7 / 8 / 8.1 / 10 | Manufacturer Warranty | 2-year warranty |
General | |
Width | 6.215 cm |
Depth | 11.66 cm |
Height | 3.82 cm |
Weight | 129.5 g |
Input Device | |
Connectivity Technology | Wired |
Interface | USB |
Buttons Qty | 6 |
Expansion / Connectivity | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type A |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
