Craft is a wireless keyboard with a premium typing experience and a versatile input dial that adapts to what you're making - keeping you focused and in your creative flow.
Product Description | Logitech Craft Advanced with Creative Input Dial - keyboard - QWERTY - UK Input Device | Device Type | Keyboard | Backlit | Yes | Interface | Bluetooth, 2.4 GHz | Wireless Receiver | USB Logitech Unifying receiver | Localization and Layout | QWERTY UK | Numeric Keypad | Yes | Dimensions (WxDxH) | 43 cm x 14.9 cm x 3.2 cm | Weight | 960 g | Manufacturer Warranty | 1-year warranty |
General | |
Backlit | Yes |
Max Operating Distance | Up to 10 m |
Features | Numeric keypad |
Width | 43 cm |
Depth | 14.9 cm |
Height | 3.2 cm |
Weight | 960 g |
Miscellaneous | |
Included Accessories | Charging cable |
Software & System Requirements | |
OS Required | Microsoft Windows 7 or later, Apple MacOS X 10.11 or later |
Battery | |
Type | Rechargeable |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
