The Bluetooth mouse that gives you the freedom to create anytime and anywhere, on the computer you choose, in all comfort.
Product Description | Logitech M535 - mouse - Bluetooth 3.0 - blue | Device Type | Mouse | Connectivity Technology | Wireless - Bluetooth 3.0 | Colour | Blue | Dimensions (WxDxH) | 6.11 cm x 10.05 cm x 3.3 cm | Weight | 82 g | Movement Detection Technology | Optical | Movement Resolution | 1000 dpi | Features | Scrolling wheel, rubber side grips, battery indicator | Battery | AA type | OS Required | Google Chrome OS, Apple MacOS X 10.8 or later, Android 3.2 (Honeycomb) or later, Microsoft Windows 7 / 8 / 10 or later | Manufacturer Warranty | 2-year warranty |
General | |
Width | 6.11 cm |
Depth | 10.05 cm |
Height | 3.3 cm |
Weight | 82 g |
Colour | Blue |
Input Device | |
Connectivity Technology | Wireless |
Interface | Bluetooth 3.0 |
Max Operating Distance | Up to 10 m |
Miscellaneous | |
Included Accessories | 1 AA battery |
Battery | |
Type | AA type |
Run Time (Up To) | 10 months |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
