ITEM | QTY | PRICE |
StarTech.com Arista Networks SFP-1G-S...
4 | £119.88 |
The ThinkPad USB Travel Mouse is compact and portable, ideal for everyday use or for those on the go. The sleek 2 button ambidextrous design ensures that this mouse is both comfortable and easy to use. It connects via USB, meaning it can be easily installed and used on virtually any device with a USB port.
Product Description | Lenovo ThinkPlus 3-Button Travel - mouse - USB - raven black - Campus | Device Type | Mouse | Connectivity Technology | Wired - USB | Colour | Raven black | Dimensions (WxDxH) | 5.4 cm x 9.5 cm x 3.2 cm | Weight | 91 g | Movement Detection Technology | Optical | Buttons Qty | 3 | Movement Resolution | 800 dpi | Features | Scrolling wheel | Cables Included | 1 x mouse cable - integrated | Manufacturer Selling Program | Lenovo Campus | Manufacturer Warranty | 1-year warranty |
General | |
Width | 5.4 cm |
Depth | 9.5 cm |
Height | 3.2 cm |
Weight | 91 g |
Input Device | |
Connectivity Technology | Wired |
Interface | USB |
Buttons Qty | 3 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compliant Standards | FCC Class B certified, CSA, UL, VCCI |
Software / System Requirements | |
Software Included | Drivers & Utilities |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - 1 year - carry-in |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 8 - 80% |
