Kingston's DCP1000 solid-state drive delivers a lot of IOPS from a single device, with ultra-low transactional latency and high throughput, making it ideal for data centers requiring extreme performance. It features ultra-fast NVMe PCIe Gen 3.0 and hardware-based pFail.
Product Description | Kingston SSDNow DCP1000 - SSD - 1.6 TB - PCIe 3.0 x8 (NVMe) | Type | Solid state drive - internal | Capacity | 1.6 TB | Interface | PCIe 3.0 x8 (NVMe) | Data Transfer Rate | 7 GBps | Features | Online Transaction Processing (OLTP), half-height half-length form-factor, High-Performance Computing (HPC), Non-volatile Flash Memory, power failure protection, Power Loss Protection (PLP), ultra-low transactional latency, S.M.A.R.T. | Dimensions (WxDxH) | 18 mm x 168 mm x 69 mm | Weight | 209 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 1.6 TB |
Width | 18 mm |
Depth | 168 mm |
Height | 69 mm |
Weight | 209 g |
Performance | |
SSD Endurance | 1820 TB |
Drive Transfer Rate | 7 GBps (external) |
Internal Data Rate | 6800 MBps (read) / 6000 MBps (write) |
4KB Random Read | 1100000 IOPS |
4KB Random Write | 200000 IOPS |
Reliability | |
MTBF | 2,000,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x PCI Express 3.0 x8 (NVMe) |
Power | |
Power Consumption | 35 Watt (active) |
Software & System Requirements | |
OS Required | Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8.1 / 10, VMware vSphere 6.0, Linux Kernel 3.3, FreeBSD 11 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years , Technical support |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 85 °C |
Vibration Tolerance (operating) | 2.17 g @ 7-800 Hz |
Vibration Tolerance (non-operating) | 20 g @ 10-2000 Hz |
