Reach max performance with PCIe 4.0. Experience longer-lasting, opponent-blasting speed. The in-house controller's smart heat control delivers supreme power efficiency while maintaining ferocious performance that always keeps you at the top of your game.
Product Description | Samsung 990 PRO MZ-V9P2T0GW - SSD - 2 TB - PCIe 4.0 x4 (NVMe) | Type | Solid state drive - internal | Capacity | 2 TB | Integrated Heatsink | Yes | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | NAND Flash Memory Type | Multi-level cell (MLC) | Form Factor | M.2 2280 | Interface | PCIe 4.0 x4 (NVMe) | Features | Sleep mode, Auto Garbage Collection Algorithm, Dynamic Thermal Guard protection, Samsung V-NAND 3bit MLC Technology, 2 GB Low Power DDR4 SDRAM Cache, S.M.A.R.T., NVMe 2.0 | Dimensions (WxDxH) | 24.3 mm x 80 mm x 8.2 mm | Weight | 28 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 2 TB |
Width | 24.3 mm |
Depth | 80 mm |
Height | 8.2 mm |
Weight | 28 g |
Performance | |
Internal Data Rate | 7450 MBps (read) / 6900 MBps (write) |
Maximum 4KB Random Write | 1550000 IOPS |
Maximum 4KB Random Read | 1400000 IOPS |
Reliability | |
MTBF | 1,500,000 hours |
Expansion & Connectivity | |
Interfaces | PCI Express 4.0 x4 (NVMe) |
Compatible Bay | M.2 2280 |
Power | |
Power Consumption | 5.8 Watt (read) , 5.1 Watt (write) , 55 mW (idle) , 5 mW (L1.2 mode) |
Software & System Requirements | |
Software Included | Samsung Magician Software |
Miscellaneous | |
Compliant Standards | IEEE 1667 |
Package Details | Box |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years / 1200 TBW |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 85 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Shock Tolerance (non-operating) | 1500 g |
Vibration Tolerance (non-operating) | 20 g @ 20-2000 Hz |
