Kensington SD3650 USB 3.0 Dual Dock DP/HDMI
Key features
  • DisplayLink driver installation required Download software from Kensington.com or via Windows update
  • No of monitors supported: 2
  • Resolution: Single monitor: 2560 x 1600 @ 60Hz and Dual monitors: 2048 x 1152 @ 30Hz
Product codes
chevron icon
chevron icon
Preserve the convenience of one-cable connectivity to your entire desktop setup with the SD3650 Universal USB 3.0 Docking Station from Kensington, a trusted leader in productivity solutions for more than 30 years. What makes the SD3650 unique from the SD3600 is that you can output dual HD video using DisplayPort and HDMI ports, plus we increased the USB 3.0 accessory expansion ports to four, ideal for a flash drive so it can transfer data at 5Gbps. The dock also features Zero Footprint Mounting, so it can be mounted to the back of a VESA-compatible monitor using a Docking Station Mount (sold separately), perfect for desks with limited space.
chevron icon
Product Description Kensington SD3650 5Gbps USB 3.0 Dual 2K Docking Station DisplayPort & HDMI - Windows - docking station - USB - HDMI, DP - 1GbE
Product Type Docking station
Docking Interface USB
Video Interfaces HDMI, DP
Dimensions (WxDxH) 19.8 cm x 8 cm x 3.4 cm
Weight 500 g
Colour Black
Networking Gigabit Ethernet
Power Power adapter DC 5 V
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
