Jabra STEEL is a Bluetooth headset specifically designed for rough working environments. The superior, state-of-the-art headset has been developed using Jabra's 145 years of R&D expertise in delivering audio innovation.
Following an extensive examination of the daily needs of trade professionals and craft workers, Jabra has created a highly durable headset to meet the specific needs of those with the toughest jobs, whether on-site in high winds, covered in dirt or under a kitchen sink. Jabra STEEL has been tested rigorously, by exposing it to high drops on to hard surfaces, testing it for water (and other liquid, such as paint) and dust ingress, as well as vibration, temperature and squeeze testing; all of which make it the right tool for rugged environments.
When you do touch work, you need tough equipment
Keep your smartphone in your pocket. Jabra STEEL is designed to resist dust, dirt, grime and water. It's even shock resistant, so it can take a drop from up high.
Introducing our toughest headset ever
Jabra STEEL is an industrial strength headset made for trade workers. Whether you are on-site and covered in dirt, or on a scaffold in high winds, Jabra Steel will keep you connected in any of the tough environments that you find yourself in.
Just Leave Your Glove on
Do you use gloves at work? Jabra Steel has extra-large buttons, sealed to resist water and dust, so you have easy access to Siri/Google Now, even with your gloves on. When you get a call, just say "answer" to pick it up.
Product Description | Jabra Steel - headset | Product Type | Headset - Bluetooth - wireless - NFC | Headphones Form Factor | Ear-bud | Connectivity Technology | Wireless | Wireless Technology | Bluetooth | Bluetooth Version | Bluetooth 4.1 | Sound Output Mode | Mono | Impedance | 16 Ohm | Microphone Operation Mode | Mono | Manufacturer Warranty | 5-year warranty |
General | |
Width | 1.54 cm |
Depth | 7.15 cm |
Height | 2.55 cm |
Weight | 10 g |
Body Material | Polypropylene, silicone rubber, PC/ABS, thermoplastic elastomer (TPE) |
Protection | Waterproof, shockproof, dust-resistant |
Max Operating Distance | 30 m |
Audio Output | |
Bluetooth Profiles | Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Phonebook Access Profile (PBAP) |
Simultaneously Connectable Devices Qty | 8 |
Microphone | |
Frequency Response | 300 - 3400 Hz |
Signal-to-Noise Ratio | 14 dB |
Audio Input Details | Omni-directional |
Wireless Link | |
Transmission Range | 30 m |
Connections | |
Connector Type | USB (5 pin Micro-USB Type B (power only)) |
Miscellaneous | |
Included Accessories | 2 earhooks, 3 pairs of EarGels, USB charger, 2 windsocks |
Power | |
Battery | Handset battery rechargeable |
Run Time (Up To) | 6 hour(s) |
Standby Time | 240 hours |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
