ITEM | QTY | PRICE |
StarTech.com 2 Port PCI Express PCIe...
4 | £55.04 |
Engineered to keep you productive. Lightweight, portable, reliable, comfortable. It's time to get ahead with this standard of professionalism. From open office to open-plan living, Evolve2 30 opens doors to enhanced comfort, seamless collaboration and instant concentration anywhere, whoever you are and however you work. Work smarter with the Jabra Evolve2 30.
Product Description | Jabra Evolve2 30 SE MS Stereo - headset | Product Type | Headset - wired - USB-C | Recommended Use | Phone, computer - communication | Headphones Form Factor | On-ear | Connectivity Technology | Wired | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 20 - 20000 Hz - Sensitivity 115 dB | Max Input Power | 30 mW | Noise Isolating | Yes | Microphone | Boom | Microphones Included | 2 | Controls | Mute, volume, answer/end, play/pause, next/previous track | Software Certification | Certified for Microsoft Teams | Manufacturer Warranty | 2-year warranty |
General | |
Width | 13.62 cm |
Depth | 5.43 cm |
Height | 17.87 cm |
Weight | 125 g |
Headband Material | Stainless steel, foam, leatherette |
Earpad Material | Leatherette, foam |
Audio Output | |
Frequency Response | 20 - 20000 Hz |
Sensitivity | 115 dB |
Diaphragm | 28 mm |
Features | Busy light, SafeTone technology, Jabra Direct, Jabra Xpress |
Audio Output Details | Multimedia - 20 - 20000 , Communication - 100 - 12000 |
Microphone | |
Type | Boom |
Form Factor | Headset microphone |
Remote Control | |
Connections | |
Connector Type | Headset (24 pin USB-C) |
Cable | |
Cable Length | 1.5 m |
Miscellaneous | |
Included Accessories | Carrying pouch |
Cable Details | Headset cable - 1.5 m |
Compliant Standards | Plug and Play, G616 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 17 cm |
Shipping Depth | 4 cm |
Shipping Height | 21.3 cm |
