Exercise is about freedom, about pushing limits and enjoying doing it. Some people like to exercise while listening to music, some talk on the phone. With the Jabra Sport Bluetooth stereo headset it's easy to do both - and without the hassle of headset wires that slow you down. You simply stream music and calls via Bluetooth to it.
With the Jabra Sport you get exceptional music and call sound quality. It has A2DP, AM3D power bass audio enhancement and a wind-shielded microphone and virtual surround sound audio enhancements. It also has a built-in FM radio so you can tune in to your favorite station while you work out.
The Jabra Sport is ultra-light and easy to wear. With a choice of different ear gels and a flexible behind-the-ear fit, it stays firmly Eargels and comfortably in place. It's also tough. With military grade rain, dust and shock protection it is fit for any challenge, indoors or outdoors.
Product Description | Jabra Sport Coach - earphones with mic | Product Type | Earphones - Bluetooth - wireless - NFC | Recommended Use | Portable electronics | Colour | Red | Headphones Form Factor | In-ear | Connectivity Technology | Wireless | Wireless Technology | Bluetooth | Headphones Technology | Dynamic | Bluetooth Version | Bluetooth 4.0 | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 20 - 20000 Hz - Sensitivity 94 dB | Impedance | 16 Ohm | Max Input Power | 5 mW | Microphone | On-cable | Manufacturer Warranty | 1-year warranty |
General | |
Width | 2.1 cm |
Depth | 3.2 cm |
Height | 1.8 cm |
Weight | 16 g |
Colour | Red |
Protection | Weatherproof, shockproof, sweat-resistant |
Max Operating Distance | 10 m |
Audio Output | |
Bluetooth Profiles | Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP) |
Frequency Response | 20 - 20000 Hz |
Sensitivity | 94 dB |
Diaphragm | 6 mm |
Microphone | |
Type | On-cable |
Frequency Response | 100 - 8000 Hz |
Tracking | |
Sensors | Motion sensor |
Wireless Link | |
Transmission Range | 10 m |
Connections | |
Connector Type | USB (5 pin Micro-USB Type B (power only)) |
Miscellaneous | |
Included Accessories | Protective pouch, 2 cable clips, 3 pairs of EarWings, 4 pairs of EarGels |
Cable Details | Headphones cable - 60 cm , USB cable - 31 cm |
Power | |
Battery | Headphone battery rechargeable |
Run Time (Up To) | 5.5 hour(s) |
Standby Time | 240 hours |
Recharge Time | 2 hour(s) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
