We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The BIZ 2400 II offers outstanding sound at both ends of the call for a superior customer experience, a corded professional headset that delivers outstanding sound on both ends of the call. Up to 40% lighter than competing headsets and with a low pressure, super-soft leatherette headband, the Biz 2400 II allows the agent to focus on their customer conversation in unrivalled comfort.
Better conversation
The most important function of a contact centre headset is eliminating background noise from the busy environment and letting the customer hear your voice clearly. The ultra-noise-cancelling microphone provides the highest degree of background noise elimination in any of our headsets.
Jabra BIZ 2400 II USB UC Mono is a stereo headset that provides USB connectivity to all leading UC applications and softphones.
Product Description | Jabra BIZ 2400 II USB Mono CC - headset | Product Type | Headset - wired - USB | Recommended Use | Portable electronics, computer - communication | Headphones Form Factor | On-ear - convertible | Connectivity Technology | Wired | Sound Output Mode | Mono | Audio Specifications | Frequency Response 60 - 1600 Hz | Max Input Power | 20 mW | Microphone | Boom | Microphone Noise Cancelling | Yes | Controls | Volume, mute button, answer/end, programmable button |
General | |
Width | 2.7 cm |
Depth | 13.9 cm |
Height | 16.7 cm |
Earpad Material | Leatherette, foam |
Protection | Breath-resistant |
Audio Output | |
Frequency Response | 60 - 1600 Hz |
Diaphragm | 30 mm |
In-Cord Volume Control | Yes |
Adjustable Headband | Yes |
Features | PeakStop technology, FreeSpin technology |
Microphone | |
Type | Boom |
Form Factor | Headset microphone |
Remote Control | |
Connections | |
Connector Type | Headset (4 PIN USB Type A) |
Cable | |
Cable Length | 2.3 m |
Miscellaneous | |
Included Accessories | Clothing clip, neckband, 2 earhooks |
Cable Details | Headset cable - Kevlar reinforced - 2.3 m |
Compliant Standards | G616 |
