Increase workforce productivity, enhance team communication and enable idea sharing. Simple and fast solutions that work with the tools you already use.
Product Description | HP Collaboration - keyboard - UK Input Device | Device Type | Keyboard | Interface | 2.4 GHz | Wireless Receiver | USB wireless receiver | Connectivity Technology | Wireless | Localization and Layout | UK | Keys Qty | 110 | Hot Keys Function | Volume, answer call | Dimensions (WxDxH) | 43.3 cm x 14.1 cm x 1.18 cm | Weight | 662.3 g | Manufacturer Warranty | 1-year warranty |
General | |
Type | Wireless |
Keys Qty | 110 |
Region | United Kingdom |
Width | 43.3 cm |
Depth | 14.1 cm |
Height | 1.18 cm |
Weight | 662.3 g |
Miscellaneous | |
Included Accessories | Micro-USB to USB cable |
Compliant Standards | CSA, BSMI, cUL, CB, EMC, FCC Part 15, TELEC, cCSAus, SRRC, NCC, RCM |
Software & System Requirements | |
OS Required | Microsoft Windows 7, Windows 10, Windows 8.x |
Battery | |
Type | Rechargeable |
Installed Qty | 1 |
Technology | Lithium Ion |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
