Maximize small work spaces with an affordable HP ProDisplay Companion Stand, which enables you to create a compact desktop solution by combining an HP ProDisplay Monitor with your choice of platform.
Product Description | HP Companion Stand - monitor stand | Product Type | Monitor stand | Dimensions (WxDxH) | 23.6 cm x 19.2 cm x 11.9 cm | Weight | 850 g | Designed For | HP 260 G2; ProDisplay P191, P221 |
General | |
VESA Mounting Interface | 100 x 100 mm |
Dimensions (WxDxH) | 23.6 cm - 19.2 cm - 11.9 cm |
Weight | 850 g |
Miscellaneous | |
Features | HP Quick Release |
Compatibility Information | |
Designed For | HP 260 G2 , HP ProDisplay P191, P221 |
