Kensington Monitor Stand Plus - Black
£59.42
27 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • 3 height settings (3-to-6)
  • Fits any monitor up to 24" and 80 lbs
  • SmartFit System
  • Accessory Type: Stand , Monitor Stand
Product codes
chevron icon
chevron icon
Trust the brand with 20 years of ergonomic expertise for a monitor stand that works perfectly in the office and for home office professionals. Kensingtons patented SmartFit System helps you position your monitor at the correct height without need for a specialist, reducing neck, back and eye strain. The extra-wide stand has 3 height settings and can fit larger monitors while leaving storage space under the platform to maximize your desktop surface area.
chevron icon
Product Description Kensington Monitor Stand Plus with SmartFit System - monitor stand
Product Type Monitor stand
Colour Black
Dimensions (WxDxH) 30.5 cm x 39.4 cm
Weight 1.71 kg
chevron icon
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used but is in excellent condition
Ref: CRKK 048326
£13.33
product
Ref: CRKK 048326
Accessories
Packaging
Functional
Software
Manuals
£13.33
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£59.42
