See productivity soar with this high performing Color LaserJet MFP. Create A3 colour documents with excellent line and image quality. Enjoy fast print speeds; print, copy, scan, fax and digital sending functionality plus exceptional ease of use.
Product Description | HP Color LaserJet CM6030f MFP - multifunction printer - colour | Device Type | Multifunction printer | Copier Type | Digital | Fax Type | Plain paper | Printing Technology | Laser (colour) | Monthly Duty Cycle (max) | 200000 impressions | Max Copying Speed | Up to 31 ppm (mono) / up to 31 ppm (colour) | Max Copying Resolution | Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour) | Max Printing Speed | Up to 40 ppm (mono) / up to 40 ppm (colour) | Max Printing Resolution | Up to 600 x 600 dpi (mono) / up to 600 x 1200 dpi (colour) | Max Fax Transmission Speed | 33.6 Kbps | Fax Resolutions | 300 x 300 dpi | Scanning | 600 dpi | Original Size | A3 (297 x 420 mm) (max) | Original Type | Sheets | Document Feeder Capacity | 50 sheets | Media Size | A3 (297 x 420 mm) (max) | Media Type | Transparencies, envelopes, plain paper, cards, labels | Standard Media Capacity | 2100 sheets | Max Media Capacity | 2100 sheets | Output Trays Capacity | 500 sheets | Stacker | Optional | Stapler | Optional | Automatic Duplexing | Yes (copying) | Connection Availability | Yes | Interface | Gigabit LAN, Wi-Fi | Office Machine Features | Security lock slot | Dimensions (WxDxH) | 70.4 cm x 67.3 cm x 98.8 cm | Weight | 139.9 kg | Microsoft Certification | Works with Windows Vista | Environmental Standards | ENERGY STAR Qualified |
General | |
Printing Technology | Laser - colour |
Memory | |
Standard Memory | 512 MB 512 MB |
Max Supported Memory | 1 GB 1 GB |
Hard Disk Drive | 80 GB |
Copying | |
Max Document Enlargement | 200% |
Max Document Reduction | 25% |
Maximum Copies | 999 |
Automatic Duplexing | Yes |
Printing | |
Printer Drivers / Emulations | PCL 6, PostScript 3 |
Image Enhancement Technology | HP ImageREt 4800 |
Scanning | |
Optical Resolution | 600 dpi |
Grayscale Depth | 8-bit |
Fax Machine | |
Max Transmission Speed | 33.6 Kbps |
PC Faxing | Yes (send only) |
Fax Machine Features | |
One-Touch Dialing | 100 station(s) |
Broadcast Transmission | 100 stations |
Features | Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing |
Document & Media Handling | |
Max Original Size | A3 (297 x 420 mm) |
Max Media Size | A3 |
Min Media Weight | 60 g/m² |
Max Media Weight | 220 g/m² |
Supported Media Type | Transparencies, envelopes, plain paper, cards, labels |
Document & Media Handling Details | ADF - 50 sheets , Input tray - 100 sheets , 4 x input tray - 500 sheets |
Finishing Equipment | |
Connections | |
Interfaces | 1 x Gigabit LAN |
Operating System Support | MS Windows XP, MS Windows 2000, MS Windows Server 2003, Apple Mac OS X 10.3, Apple Mac OS X 10.2.8, Apple MacOS X 10.4 or later, MS Windows Vista |
Power | |
Power Consumption Operational | 920 Watt |
Power Consumption Sleep | 23 Watt |
Miscellaneous | |
Works with Windows Vista | Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running. |
Security Slot Type | Kensington security slot |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Width | 70.4 cm |
Depth | 67.3 cm |
Height | 98.8 cm |
Weight | 139.9 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 160 kg |
Environmental Parameters | |
Min Operating Temperature | 15 °C |
Max Operating Temperature | 27 °C |
Humidity Range Operating | 30 - 70% |
