Say goodbye to ink cartridges!
The ideal choice for any busy home or home office, this 3-in-1 inkjet printer can print up to 11,000 pages without the need for cartridges.
The star of the ET-3600 is its newly designed integrated ultra-high-capacity ink tank system, which completely does away with the need for ink cartridges. That means less fuss and much more printing between refills than other inkjet printers. It includes two complete sets of ink, helping you to stay stocked up for longer. They're designed to work together, so it's straightforward and mess free to fill the tank with the bottles.
Ultra-low cost-
The ET-3600 saves you 74% in printing costs on average. It achieves an ultra-low cost per page, printing up to 11,000 pages both in black and colour at just a fraction of a penny per page . Double-sided printing can also cut paper usage in half, reducing your running costs even further.
Wi-Fi and Ethernet connectivity-
Equipped with Wi-Fi and Wi-Fi Direct, the ET-3600 can take advantage of all Epson Connect4 features. Send documents to print and scan from smartphones and tablets using the free Epson iPrint4. For added flexibility, you can even email files from anywhere in the world via Epson Email Print4.
Quick, quality results-
It uses Epson's own Micro Piezo technology for excellent-quality print-outs. Mono prints are delivered at a rate of 13 pages per minute while it can issue 7.3 colour pages per minute5. For printing business documents, the black pigment ink is superb at delivering high-quality text.
Product Description | Epson EcoTank ET-3600 - multifunction printer - colour | Device Type | Multifunction printer | Printing Technology | Ink-jet (colour) | Inkjet Technology | Epson PrecisionCore - 4-ink | Max Printing Speed | Up to 13.7 ppm (mono) / up to 7.3 ppm (colour) | Max Printing Resolution | Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Scanning | 1200 x 2400 dpi | Original Type | Sheets | Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) (max) | Media Type | Envelopes, plain paper, photo paper | Standard Media Capacity | 150 sheets | Automatic Duplexing | Yes (printing) | Connection Availability | Yes | Interface | USB, Wi-Fi | Power | AC 230 V (50/60Hz) | Dimensions (WxDxH) | 48.9 cm x 30 cm x 16.9 cm | Weight | 4.7 kg | Manufacturer Warranty | 1-year warranty |
General | |
Printing Technology | Ink-jet - colour |
Memory | |
Supported Flash Memory | SD Memory Card, SDHC Memory Card, SDXC Memory Card |
Printing | |
Inkjet Technology | Epson PrecisionCore |
Nozzle Configuration | 400 nozzles (black), 128 nozzles (per colour) |
Ink Cartridge Configuration | 4 cartridges (1 each: cyan, magenta, yellow, black) |
Ink Palette Supported (Colours) | Cyan, magenta, yellow, black |
Colour | 4-ink |
Minimum Ink Droplet Size | 3.3 pl |
Automatic Duplexing | Yes |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 x 2400 dpi |
Document & Media Handling | |
Max Media Size | A4/Legal |
Supported Media Type | Envelopes, plain paper, photo paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm |
Supported Envelope Sizes | US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm) |
Document & Media Handling Details | Input tray - 150 sheets |
Speed Details | Printing: up to 33 ppm - B/W , Printing: up to 20 ppm - colour , Printing: up to 13.7 ppm - B/W (ISO/IEC 24734) , Printing: up to 7.3 ppm - colour (ISO/IEC 24734) , Printing: up to 6.5 ppm - B/W duplex (ISO/IEC 24734) , Printing: up to 4.5 ppm - colour duplex (ISO/IEC 24734) |
Connections | |
Interfaces | 1 x USB |
Security Protocols & Features | WEP, WPA-PSK, Wi-Fi Direct |
Operating System Support | MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, Windows 8.1 |
Power | |
Voltage Required | AC 230 V (50/60Hz) |
Power Consumption Operational | 13 Watt |
Power Consumption Sleep | 1.5 Watt |
Miscellaneous | |
Consumables Included | 2 x ink tank (black) , 2 x ink tank (cyan) , 2 x ink tank (magenta) , 2 x ink tank (yellow) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year / 50000 pages - carry-in |
Dimensions & Weight | |
Width | 48.9 cm |
Depth | 30 cm |
Height | 16.9 cm |
Weight | 4.7 kg |
Environmental Parameters | |
Sound Emission | 37 dBA (operating) |
