Say goodbye to cartridges
The star is its newly designed integrated ultra-high-capacity ink tank system, which completely does away with the need for ink cartridges. That means less fuss and much more printing between refills than other inkjet printers.
Two years of ink
Imagine not having to think about ink for two years. As well as doing away with ink cartridges, the ET-2500 has four colour 70ml Epson genuine ink bottles in the box, which make it easy, clean and quick to fill the ink tanks.
Ultra-low cost
The ET-2500 saves you 70% on printing costs on average. The included ink bottles can print up to 4,000 pages in black and 6,500 pages in colour at just a fraction of a penny per page4.
Mobile printing
Equipped with Wi-Fi, the ET-2500 can take advantage of Epson Connect5 features. Print quickly and easily over Wi-Fi from a smartphone using the free Epson iPrint app, print remotely or email the ET-2500 a print job from anywhere.
Quick, quality results
The ET-2500 uses Epson's own Micro Piezo technology for excellent-quality print-outs. Mono prints are delivered at a rate of 9.2 pages per minute while it can issue 4.5 colour pages per minute.
Product Description | Epson EcoTank ET-2500 - multifunction printer - colour | Device Type | Multifunction printer | Printing Technology | Ink-jet (colour) | Inkjet Technology | Epson Micro Piezo - 4-ink | Max Printing Speed | Up to 9.2 ppm (mono) / up to 4.5 ppm (colour) | Max Printing Resolution | Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour) | Scanning | 1200 x 2400 dpi | Original Type | Sheets | Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) (max) | Media Type | Envelopes, plain paper, photo paper | Standard Media Capacity | 100 sheets | Connection Availability | Yes | Interface | USB, Wi-Fi(n) | Power | AC 230 V (50/60Hz) | Dimensions (WxDxH) | 48.9 cm x 30 cm x 16.9 cm | Weight | 4.6 kg | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified |
General | |
Printing Technology | Ink-jet - colour |
Printing | |
Inkjet Technology | Epson Micro Piezo |
Nozzle Configuration | 180 nozzles (black), 3 x 59 nozzles (cyan, magenta, yellow) |
Ink Cartridge Configuration | 4 individual ink tanks |
Ink Palette Supported (Colours) | Cyan, magenta, yellow, black |
Colour | 4-ink |
Minimum Ink Droplet Size | 3 pl |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 x 2400 dpi |
Document & Media Handling | |
Max Media Size | A4/Legal |
Supported Media Type | Envelopes, plain paper, photo paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm |
Supported Envelope Sizes | US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm) |
Document & Media Handling Details | Input tray - 100 sheets |
Speed Details | Printing: up to 33 ppm - B/W , Printing: up to 15 ppm - colour , Printing: up to 9.2 ppm - B/W (ISO/IEC 24734) , Printing: up to 4.5 ppm - colour (ISO/IEC 24734) |
Connections | |
Interfaces | 1 x USB |
Operating System Support | MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, Windows 8, Windows 8.1 |
Power | |
Voltage Required | AC 230 V (50/60Hz) |
Power Consumption Operational | 11 Watt |
Power Consumption Sleep | 1.3 Watt |
Miscellaneous | |
Consumables Included | 1 x ink tank (black) - up to 4000 pages , 1 x ink tank (cyan) - up to 6500 pages , 1 x ink tank (magenta) - up to 6500 pages , 1 x ink tank (yellow) - up to 6500 pages |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Width | 48.9 cm |
Depth | 30 cm |
Height | 16.9 cm |
Weight | 4.6 kg |
Environmental Parameters | |
Sound Emission | 38 dBA (operating) |
