The 1100 SATA SSD provides exceptional performance and extremely low power consumption for client computing applications ranging from desktop gaming rigs to corporate road warrior tablets. The 1100 SSD is manufactured to excel in performance, endurance, price and power while enabling green computing. Device sleep (DEVSLP) low-power modes extend battery life, and several features protect valuable data, including Opal 2.0 self encryption, power-loss protection for data-at-rest and adaptive thermal monitoring.
Product Description | Micron 1100 - SSD - 512 GB - SATA 6Gb/s | Type | Solid state drive - internal | Capacity | 512 GB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | NAND Flash Memory Type | 16nm 3D triple-level cell (TLC) | Form Factor | M.2 2280 | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Features | Native Command Queuing (NCQ), Device Initiated Power Management (DIPM), Secure Erase function, Adaptive thermal monitoring, DEVSLP SATA low power mode, Microsoft eDrive compatible, Multi-Word DMA mode 0-2 support, Ultra DMA Mode 0-6 support, PIO mode 3, 4 support, dynamic write acceleration, S.M.A.R.T. | Dimensions (WxDxH) | 22 mm x 80 mm |
General | |
Device Type | Solid state drive - internal |
Capacity | 512 GB |
Bytes per Sector | 512 |
Width | 22 mm |
Depth | 80 mm |
Performance | |
SSD Endurance | 240 TB |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 530 MBps (read) / 500 MBps (write) |
4KB Random Read | 92000 IOPS |
4KB Random Write | 83000 IOPS |
Average Latency | 40 µs |
Reliability | |
MTBF | 1,500,000 hours |
Non-Recoverable Errors | 1 per 10^15 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s - M.2 Card |
Compatible Bay | M.2 2280 |
Power | |
Power Consumption | 55 mW (idle) , 70 mW (active) , 2 mW (sleep) , 4000 mW (maximum) |
Miscellaneous | |
Compliant Standards | TUV, RRL, ICES-003 Class B, IC, RoHS, UL 60950-1 Second Edition, KCC, WEEE, BSMI CNS 13438, FCC CFR47 Part 15 B, RCM, VCCI V-3/2011.04, Directive 2012/19/EC, OPAL 2.0, IEC60950/EN60950, IEEE 1667, KN32, KN35, EN 55032 Class B, ATA-8 ACS3, AS/NZS CISPR 32 Class B |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Shock Tolerance (non-operating) | 1500 g @ 0.5 ms |
Vibration Tolerance (non-operating) | 3.1 g @ 5-800 Hz |
