Corsair Vengeance M95 Performance MMO/RTS Gaming Mouse - White
Key features
  • Easy access to frequently-used abilities, macros, button combinations, and spells
  • Highly accurate tracking
  • Comfortable for hours of play
  • 15 intelligently positioned buttons, including nine macro keys
  • 8200 DPI laser sensor
  • Aluminum uniKeySellingPoints design
Product codes
chevron icon
chevron icon
The Vengeance M95 laser gaming mouse is designed for the complex demands of massively multiplayer and real-time strategy games. It offers 15 intelligently positioned buttons, easy programming, and onboard storage to take customized macros with you on-the-go. The 8200 DPI laser sensor gives you accurate control during intense gaming sessions. The low-mass aluminum unibody structure is covered in soft-touch materials and designed for the comfort and ergonomics you need when you're playing for hours. Plus, Vengeance M95 is available in Arctic White and Gunmetal Black to match your system or your style.
Product features:
Precise tracking for highly accurate mouse control during demanding gaming sessions
15 programmable buttons
Second-generation control panel
Makes setup and customization easier than ever
Onboard profile storage
Settings and profiles are stored directly on the mouse so you can take them with you
Aluminum unibody design
Built for low weight, high rigidity, and optimal mass distribution
Selectable response time
Choose between 1000Hz, 500Hz, 250Hz, or 125Hz (1ms, 2ms, 4ms or 8ms)
High-mass scroll wheel
Solid metal, rubberized scroll wheel for precise tactile feedback
20 million click switches
Highly durable buttons that stand up to hours of gaming
Soft-touch and textured surfaces
Outstanding comfort during multi-hour play sessions
PTFE glide pads
Low-friction glide pads ensure swift, precise movements
chevron icon
Product Description CORSAIR Vengeance M95 Performance MMO and RTS Gaming - mouse - USB - arctic white
Device Type Mouse
Connectivity Technology Wired - USB
Colour Arctic white
Weight 160 g
Localisation Europe
Movement Detection Technology Laser
Buttons Qty 15
Movement Resolution 8200 dpi
Performance 30 G maximum acceleration, 2 ms response time, 1 ms response time, 500 reports per second, 1000 reports per second, 125 reports per second, 8 ms response time, 250 reports per second, 4 ms response time, up to 150 inches per second
Features Profile switch, backlighting, polytetrafluoroethylene (PTFE) feet, on-the-fly DPI switching, rubberised scroll wheel, aluminium body, automatic surface quality detection
Cables Included 1 x USB cable - integrated - 1.8 m
OS Required Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
