Wi-Fi-equipped A4 multifunctional that’s compact and easy to operate. The complete solution for small and home offices. This compact Wi-Fi enabled A4 laser multifunctional offers high-quality print, scan and fax capabilities that are effortless to use via your PC, smartphone or tablet.
Product Description | Canon i-SENSYS MF628Cw - multifunction printer - colour | Device Type | Multifunction printer | Fax Type | Super G3 - plain paper | Printing Technology | Laser (colour) | Monthly Duty Cycle (max) | 30000 pages | Recommended Monthly Volume | 1500 pages | Max Copying Speed | Up to 14 ppm (mono) / up to 14 ppm (colour) | Max Copying Resolution | Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour) | Max Printing Speed | Up to 14 ppm (mono) / up to 14 ppm (colour) | Max Printing Resolution | Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour) | Max Fax Transmission Speed | 33.6 Kbps | Fax Resolutions | 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi | Scanning | 600 x 600 dpi | Original Size | 128 x 139.7 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max) | Original Type | Sheets | Document Feeder Capacity | 50 sheets | Media Size | 83 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max) | Media Type | Transparencies, envelopes, plain paper, cards, labels, recycled paper, coated paper, heavy-weight paper | Standard Media Capacity | 150 sheets | Bypass Feeder Capacity | 1 sheet | Output Trays Capacity | 125 sheets | Connection Availability | Yes | Interface | USB 2.0, LAN, Wi-Fi(n), USB host | AirPrint Enabled | Yes | Office Machine Features | Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, scan to PC | Power | AC 230 V (50/60Hz) | Dimensions (WxDxH) | 43 cm x 48.4 cm x 42.9 cm | Weight | 26 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Fax Type | Plain paper |
Printing Technology | Laser - colour |
Display Features | Touch screen |
Memory | |
Standard Memory | 512 MB |
Copying | |
Grayscale Half-Tones | 256 |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 99 |
Copying Features | Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy |
Printing | |
Printer Drivers / Emulations | UFRII LT, TIFF |
First Print Out Time B/W | 18 sec |
First Print Out Time Colour | 18 sec |
Scanning | |
Optical Resolution | 600 x 600 dpi |
Interpolated Resolution | 9600 x 9600 dpi |
Colour Depth | 24-bit |
Colour Depth (Internal) | 24-bit |
Fax Machine | |
Compatibility | Super G3 |
Max Transmission Speed | 33.6 Kbps |
Total Memory Capacity | Up to 512 pages |
PC Faxing | Yes |
Fax Machine Features | |
Error Correction Mode (ECM) | Yes |
Speed Dialing | 281 station(s) |
Broadcast Transmission | 310 stations |
Features | Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, remote reception, Dual Access, fax memory backup, fax activity reports |
Document & Media Handling | |
Min Original Size | 128 x 139.7 mm |
Max Original Size | Legal (216 x 356 mm)/A4 (210 x 297 mm) |
Min Media Size | 83 x 127 mm |
Max Media Size | A4/Legal |
Min Media Weight | 60 g/m² |
Max Media Weight | 220 g/m² |
Supported Media Type | Transparencies, envelopes, plain paper, cards, labels, recycled paper, coated paper, heavy-weight paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 215.9 x 355.6 mm, 83 x 127 mm, Foolscap (216 x 343 mm) |
Supported Envelope Sizes | International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm) |
Document & Media Handling Details | ADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 150 sheets size: 83 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 83 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 125 sheets |
Speed Details | Printing: up to 14 ppm (A4) - B/W , Printing: up to 14 ppm (A4) - colour , Copying: up to 14 ppm (A4) - B/W , Copying: up to 14 ppm (A4) - colour , Scanning: up to 14 ipm - B/W , Scanning: up to 14 ipm - colour |
Connections | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A |
Security Protocols & Features | IPsec, 802.1x, Wi-Fi Direct |
Operating System Support | Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, MS Windows Server 2012, Windows 8, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10 |
Software Included | Drivers & Utilities, Presto! PageManager, Canon Print Service Plug-in for Android |
Power | |
Voltage Required | AC 230 V (50/60Hz) |
Power Consumption Operational | 900 Watt |
Power Consumption Standby | 20 Watt |
Power Consumption Sleep | 1 Watt |
Miscellaneous | |
First Copy Out Time B/W | 19 sec |
First Copy Out Time Colour | 19 sec |
Consumables Included | 1 x toner cartridge (black) - up to 800 pages , 1 x toner cartridge (cyan) - up to 800 pages , 1 x toner cartridge (magenta) - up to 800 pages , 1 x toner cartridge (yellow) - up to 800 pages |
Compliant Standards | ISO/IEC 19798 |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Width | 43 cm |
Depth | 48.4 cm |
Height | 42.9 cm |
Weight | 26 kg |
Environmental Parameters | |
Sound Emission | 48 dBA (idle) / 65.2 dBA (operating) |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 30 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
