Today's mission critical advanced Fast Ethernet and Gigabit computer networks require the stability and reliability of Enhanced Category 5 high-speed cabling to distribute data, voice and video. To protect your high-speed network from noise and electromagnetic interference, use Shielded Enhanced CAT5 Patch Cables from C2G. The molded boot provides extra strain-relief and durability. C2G Shielded Enhanced CAT5 Patch Cables are available in a variety of colors to easily color-code your network installation.
Product Description | C2G Cat5e Booted Shielded (STP) Network Patch Cable - patch cable - 2 m - black | Type | Patch cable - CAT 5e | Technology | Shielded twisted pair (STP) | Wiring Scheme | T568B | Shielding Material | Foil | Wires per Cable | 8 wires | Features | Molded | Length | 2 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Black |
General | |
Network Cable Type | Patch cable - CAT 5e |
Jacket Material | PVC |
American Wire Gauge (AWG) | 24 |
Pairs per Cable | 4 pairs |
Plated Connector | Gold |
Features | Molded |
Length | 2 m |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
