ITEM | QTY | PRICE |
C2G 3m Velocity™ TOSLINK® Optica...
2 | £35.72 |
LG 55" G3 4K UltraHD HDR Smart O...
4 | £6,796.00 |
Polaroid Everything Box Polaroid Go -...
2 | £209.96 |
We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
This OM3 Duplex Multimode Fibre Optic Cable is ideal for connecting 10GBase-SR, 10GBase-LRM, SFP+ and QSFP+ transceivers for 10 gigabit network connections. This cable has a LSZH jacket which protects from toxic and corrosive gases in poorly ventilated spaces and other areas where it is most critical. This cable also provides backward compatibility with existing 50/125 equipment and the performance headroom required to support LED and VCSEL laser light sources, and 10 Gigabit Ethernet applications. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures.
Product Description | C2G LC-LC 10Gb 50/125 OM3 Duplex Multimode PVC Fiber Optic Cable (LSZH) - network cable - 2 m - aqua | Type | Network cable - OM3 | Technology | Duplex fibre optic | Type of Fibre Optics | Multimode | Features | Halogen-free | Length | 2 m | Core / Cladding Diameter | 50 / 125 micron | Connector | 2 x LC multi-mode - male | Connector (Second End) | 2 x LC multi-mode - male | Colour | Aqua | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Network cable - OM3 |
Jacket Material | Low Smoke Zero Halogen (LSZH) |
Fibre Qty | 2 |
Length | 2 m |
Colour | Aqua |
Connectivity | |
Miscellaneous | |
Compliant Standards | TIA/EIA-455-171A |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 70 °C |
