We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Cost-effective solution that provides high bandwidth and transmission rates over longer distances. With SC to SC termination, this high quality fibre optic patch cable is specifically designed for Gigabit Ethernet applications. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs. Each cable is 100% optically inspected and tested for insertion loss before you receive it. A pull-proof jacket design surrounds the popular 9/125 Single-mode fibre, immune to electrical interference.
Product Description | C2G SC-SC 9/125 OS1 Duplex Singlemode PVC Fiber Optic Cable (LSZH) - patch cable - 1 m - yellow | Type | Patch cable - OS1 | Technology | Duplex fibre optic | Type of Fibre Optics | Singlemode | Features | Halogen-free | Length | 1 m | Core / Cladding Diameter | 9 / 125 micron | Connector | 2 x SC single-mode - male | Connector (Second End) | 2 x SC single-mode - male | Colour | Yellow | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Patch cable - OS1 |
Jacket Material | Low Smoke Zero Halogen (LSZH) |
Fibre Qty | 2 |
Length | 1 m |
Colour | Yellow |
Connectivity | |
Miscellaneous | |
Compliant Standards | TIA/EIA-455-171A |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 70 °C |
