Featuring impressive design, Magic Mouse 2 is completely rechargeable, so you'll eliminate the use of traditional batteries. It's lighter, has fewer moving parts thanks to its built-in battery and continuous bottom shell, and has an optimized foot design - all helping Magic Mouse 2 track easier and move with less resistance across your desk. And the multi-touch surface allows you to perform simple gestures such as swiping between web pages and scrolling through documents. Magic Mouse 2 is ready to go right out of the box and pairs automatically with your Mac.
Product Description | Apple Magic Mouse 2 - mouse - Bluetooth - space grey | Device Type | Mouse | Connectivity Technology | Wireless - Bluetooth | Colour | Space grey | Dimensions (WxDxH) | 5.71 cm x 11.35 cm x 2.16 cm | Weight | 99 g | Multi-Touch | Yes | Features | Scrolling, gesture function | OS Required | Apple MacOS X 10.11 or later |
General | |
Width | 5.71 cm |
Depth | 11.35 cm |
Height | 2.16 cm |
Weight | 99 g |
Input Device | |
Connectivity Technology | Wireless |
Interface | Bluetooth |
Multi-Touch | Yes |
Miscellaneous | |
Included Accessories | Lightning to USB cable |
Software / System Requirements | |
