BT.com
Wishlist
Zyxel VMG1312-B10D Wireless N VDSL2 4-port Gateway with USB
Zyxel VMG1312-B10D Wireless N VDSL2...
£50.85
22 in stock
£50.85
Add to wishlist
Delivery
Standard 3-5 working days
The ZyXEL VMG1312-B Series Wireless N VDSL2 4-port Gateway with USB supports Vectoring technology to eliminate crosstalk or interference among different VDSL lines. In the mechanism, Vectoring significantly increases bit rates to compete with cable/fiber technology as well as to enlarge service coverage without changing the current infrastructure - a way to significantly save cost comparing to fiber-to-the-home (FTTH) deployments, while the CAPEX can be optimized by improved data rates and coverage without upgrading equipment. 2.4 GHz 11n (2x2) for superior performance and coverage.
ZyXEL VMG1312-B10D - wireless router - DSL modem - 802.11b/g/n - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, VDSL, ADSL2, ADSL2+, READSL, VDSL2
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Maximum number of configured SSIDs: 4 , ACL rules: 32
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, PPPoE, PPPoA, ARP
Routing Protocol
IGMP
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, HTTP, TFTP, SSH, CLI
Firewall protection, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, packet filtering, URL filtering, parental control, firmware upgradable, Access Control List (ACL) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, Multiple SSID support, hidden SSID, DNS proxy, reset button, DHCP relay, DHCP client, NTP time synchronisation, Class of Service (CoS), DiffServ Code Point (DSCP) support, Seamless Rate Adaptation (SRA), Rom-D support, scheduler
IEEE 802.1Q, ANSI T1.413, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
15.8 cm x 11.45 cm x 2.2 cm
186 g
Europe
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
IGMP
Encryption Algorithm
128-bit WEP, 64-bit WEP, TLS, WPA, WPA2, WPA-PSK, WPA2-PSK
Authentication Method
PAP, CHAP, Radio Service Set ID (SSID), MS-CHAP, MS-CHAP v.2, Extensible Authentication Protocol (EAP)
IEEE 802.1Q, ANSI T1.413, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n , FCC
Status Indicators
Power, WLAN, LAN, USB, WPS, Internet, DSL
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.993.2, ITU G.993.5
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
2
10.4 Watt
Europe
15.8 cm
11.45 cm
2.2 cm
186 g
20 - 95% (non-condensing)
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been opened but is in excellent condition
Ref: BW64 035160
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£33.70
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
