Payday Tech Sale: The Biggest Brands. The Biggest Savings. Treat yourself to some new tech.
WD WD_BLACK C50 Storage Expansion Card for Xbox 512GB
£94.99
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Leverages Xbox Velocity Architecture and delivers similar performance as your Xbox Series X|S internal storage for a seamless experience
  • Plug-and-play with your Xbox Series X|S, so you don't have to worry about compatibility or opening your console to install
  • Quick Resume-compatible, allowing you to suspend your current game, play a different game, then come back to the first game as if you never left
  • Form Factor: Media Drive
  • Capacity: 512GB, 251-500GB
  • Interface: Xbox Series X/S
Product codes
chevron icon
chevron icon
Say hello to more for your Xbox. As game files get larger, the WD BLACK C50 Expansion Card for Xbox is the fast and easy way to give your Xbox Series X|S a big capacity boost and keep more titles installed. Just plug this officially licensed card directly into the console for similar performance as the Xbox internal storage.
chevron icon
Product Description WD Black C50 Expansion Card for XBOX - hard drive - 512 GB
Type Hard drive - external (portable)
Capacity 512 GB
Features Xbox compatible
Dimensions (WxDxH) 31.6 mm x 55.6 mm x 7.7 mm
Weight 25 g
Manufacturer Warranty 5-year warranty
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£94.99
