BT.com
Wishlist
WD Red 8TB NAS Desktop Hard Drive 3.5" SATA 6Gb/s 128MB 5400rpm
WD Red 8TB NAS Desktop Hard Drive...
£286.51
Hurry, only 1 left in stock!
£286.51
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
WD Red™: The colour of NAS.
WD Red is designed for NAS systems that have 1-8 drive bays. Available in capacities ranging from 1TB to 8TB, WD Red is designed specifically for home and small office NAS systems. The drives are extensively tested for compatibility and reliability in the demanding operating environment of a 24x7 NAS system. WD's exclusive NASware™ firmware technology enables seamless integration and balanced performance. Innovative technology reduces power comsumption and lowers the operating temperature, and with a 35% improvement in MTBF over desktop drives, WD Red is a more reliable and robust NAS hard drive solution.
• Designed specifcally for home and small office NAS systems - WD Red is the only hard drive for 1-8 bay systems
• Exclusive NASware™ technology - advanced firmware for seamless integration and optimal performance
• Energy efficient and reliable - Innovative technology reduces power consumption and operating temperature
WD Red NAS Hard Drive WD80EFZX - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal
8 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
5400 rpm
Advanced Format technology, NAS compatible, NASware technology, 3D Active Balance Plus, 24x7 availability
101.6 mm x 147 mm x 26.1 mm
650 g
3 years warranty
8 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
128 MB
101.6 mm
147 mm
26.1 mm
650 g
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
5400 rpm
Reliability
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
6.4 Watt (read) , 6.4 Watt (write) , 5.2 Watt (idle) , 0.4 Watt (sleep) , 0.4 Watt (standby)
Apple MacOS, Linux, Microsoft Windows
RoHS
Limited warranty - 3 years
70 °C
Shock Tolerance (operating)
65 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Sound Emission
29 dBA
WD Red 8TB NAS Desktop Hard Drive 3.5" SATA 6Gb/s 128MB...
£286.51
Save on this ideal PC Build kit!
Save £10.63
£305.68
Cables - Cables
£286.51
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.22
£289.73
Scroll to top
