ITEM | QTY | PRICE |
Razer BlackWidow V3 Mini HyperSpeed (...
2 | £318.00 |
NETGEAR Prosafe 24GE POE Smart Switch
3 | £1,080.30 |
StarTech.com RCA to F Type Coaxial Ad...
2 | £8.84 |
Equipped with USB-C technology, the My Passport Ultra for Mac portable drive offers an easy way to expand your storage.
Product Description | WD My Passport Ultra for Mac WDBPMV0040BSL - hard drive - 4 TB - USB 3.0 | Type | Hard drive - external (portable) | Capacity | 4 TB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | Interface | USB 3.0 - USB-C | Data Transfer Rate | 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0) | Features | Password authentication, automatic backup, Apple Time Machine compatible, HFS+ formatted | Power Source | USB bus | Enclosure Colour | Silver | Dimensions (WxDxH) | 81.6 mm x 110 mm x 20.96 mm | Weight | 230 g | Localisation | Worldwide (excluding China, Japan) | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Hard drive - external (portable) |
Capacity | 4 TB |
Interface | USB 3.0 |
Width | 81.6 mm |
Depth | 110 mm |
Height | 20.96 mm |
Weight | 230 g |
Performance | |
Interface Transfer Rate | 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 - 24 pin USB-C |
Power | |
Software & System Requirements | |
Software Included | WD Security, WD Drive Utilities, WD Backup, WD Discovery |
OS Required | Apple MacOS, Microsoft Windows 7 / 8.1 / 10 |
Miscellaneous | |
Cables Included | 1 x USB-C to USB-A adapter - external |
Compliant Standards | Directive 2002/95/EC |
Package Type | Retail |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 65 °C |
Humidity Range Operating | 20 - 80% |
