ITEM | QTY | PRICE |
OtterBox Symmetry Clear Apple iPad 8t...
3 | £92.28 |
LG 50" UR7800 4K Ultra HD Smart TV
3 | £897.00 |
Sophisticated performance enhancing features deliver the speed you need for demanding applications like photo and video editing and Internet gaming.
High performance, high capacity, high reliability, and cutting-edge technology make up WD Black, the ideal drive for those who demand only the best.
Product Description | WD Black Performance Hard Drive WD2003FZEX - hard drive - 2 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 2 TB | Form Factor | 3.5" x 1/3H | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 64 MB | Spindle Speed | 7200 rpm | Features | StableTrac, NoTouch ramp load technology, dual processor, Advanced Format technology, S.M.A.R.T. | Dimensions (WxDxH) | 101.6 mm x 147 mm x 25.4 mm | Weight | 750 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 2 TB |
Width | 101.6 mm |
Depth | 147 mm |
Height | 25.4 mm |
Weight | 750 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 164 MBps |
Reliability | |
Non-Recoverable Errors | 1 per 10^14 |
Load / Unload Cycles | 300,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s - 7 pin Serial ATA |
Compatible Bay | 3.5" x 1/3H |
Power | |
Power Consumption | 9.5 Watt (read) , 8.1 Watt (idle) , 1.3 Watt (standby) , 1.3 Watt (sleep) |
Miscellaneous | |
Compliant Standards | RoHS, WEEE |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 55 °C |
Shock Tolerance | 65 g @ 2ms (operating) / 300 g @ 2ms (non-operating) |
Sound Emission | 29 dBA |
