Mini drive. Mega capacity. Multi colors.
My Passport® offers high capacity in a sleek portable drive. It features ultra-fast USB 3.0 connectivity; compatibility with USB 2.0; automatic, backup software; and password protection and hardware encryption to help protect your files from unauthorized use. With up to 2 TB capacity, there's plenty of room to store all your photos, music, movies and files.
Ideal For
Kit Contents
Compatibility
Formatted NTFS for Windows® XP, Windows Vista®, Windows 7 Can be reformatted for Mac® OS X® Leopard, Snow Leopard™ or Lion™
Warranty
Product Description | WD My Passport WDBKXH5000ARD - hard drive - 500 GB - USB 3.0 | Type | Hard drive - external | Capacity | 500 GB | Hardware Encryption | Yes | Interface | USB 3.0 | Data Transfer Rate | 5.0 Gbps (USB 3.0) | Features | Hardware encryption | Power Source | USB bus | Enclosure Colour | Red | Dimensions (WxDxH) | 8.2 cm x 11.1 cm x 1.5 cm | Weight | 138 g | Localisation | Middle East, Africa, Europe | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Hard drive - external |
Capacity | 500 GB |
Width | 8.2 cm |
Depth | 11.1 cm |
Height | 1.5 cm |
Weight | 138 g |
Performance | |
Interface Transfer Rate | 5.0 Gbps (USB 3.0) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 |
Power | |
Software & System Requirements | |
OS Required | Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X Lion 10.7 |
Miscellaneous | |
Cables Included | 1 x USB cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
